Team Associated F1 >
Team Associated F1
Like Tree331Likes
Team Associated F1
Old 12-07-2017, 03:02 PM
  #736
Billy Kelly's Avatar
Originally Posted by DoubleRR24
Just picked up this kit recently for my introduction to F1. It was a really fun build and I can't wait to get it out on the track. For those that have or are currently racing it, what are the spare parts you recommend that I have on hand?
Front wing and the side links. Broke 3 wings over 14 race days. And around 8-10 side links. I bought a set of XRay links to try. But Iím still months away from running F1 again.
Billy Kelly is offline
Old 12-07-2017, 03:28 PM
  #737
Thank you for this!
DoubleRR24 is offline
Old 12-08-2017, 05:55 AM
  #738
Just so I understand you correctly, when you say the side links, you are referring to the rear pod links?
Old 12-08-2017, 06:56 AM
  #739
Yes. Iíd forgotten the correct name.
They have been my only real weak point. Iím sure couple were my fault for over tightening, or collisions. Few times they just to break. Itís a cheap quick repair. Just made sure to keep spares.
Old 12-08-2017, 12:01 PM
  #740
what would the valonte tire be for soft and med front and rear tire assy mounted?
larrym is offline
Old 12-08-2017, 07:44 PM
  #741
Thank you. I appreciate the tip.
Old 12-09-2017, 05:40 PM
  #742
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Can you ask again? I just picked up a set of the carpet rears, Med fronts and Med Hard fronts.
liljohn1064 is offline
Old 01-09-2018, 07:26 PM
  #743
1/4milecrazy's Avatar
Still no input on the forward servo position?
1/4milecrazy is offline
Old 01-10-2018, 10:20 AM
  #744
Is there a setup system available for F1 cars?
Old 01-10-2018, 11:24 AM
  #745
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Yes, Hudy has one but don't buy it. If you have a 1/10th station, all the Hudy F1 setup system basically is the front half of the 1/10th TC system and just adding a spacer for the F1 axles. You can probably buy the spacers alone or a similarly sized bearings.
Honestly, the Turnigy Trackstar 1/10 and 1/12 pan car setup system is better to get more accurate readings. Yes, the quality sucks (hard to see the markings) but it has a threaded insert for the plate that fits F1 axles perfectly and lets you get at the base of the axle.
Once I got my Hudy F1 setup station and saw what it was, I sold it. I already had a Hudy 1/10th TC station and the Trackstar pan car setup station.
https://hobbyking.com/en_us/tracksta...up-system.html
Dan is offline
Old 01-10-2018, 10:15 PM
  #746
kyle3333's Avatar
Hello, I just picked up this kit today. I got the F1-Fifteen body and I'm trying to figure out how the cut-out templates work for the front suspension and steering. Does anyone have any tips? Also, what is the best way to figure out where the body post holes go?
kyle3333 is offline
Old 01-11-2018, 06:26 AM
  #747
Trader Rating: 39 (100%+)
I like to mark the body holes before I paint if I can. If not I shine a light from underneath to see where the body posts hit.
hobbyten is offline
Old 01-11-2018, 07:52 AM
  #748
scirocco14's Avatar
Best RC tool ever! https://www.prolineracing.com/protof...-mounting-kit/
Once I got these, no more problems locating the body post holes.
Mark
scirocco14 is offline
Old 01-11-2018, 08:58 AM
  #749
qcrc's Avatar
Aarowmax has the spacers that you are talking about. I just bought a set but haven't used them yet.
AM-170050 Alu 1/10 Formula Set-Up Wheel Axle Adapter - Setup Tools
qcrc is offline
Old 01-11-2018, 11:42 PM
  #750
Is it a secret? Has anybody tried anything besides kit set-ups? Battery forward? Servo forward? Battery inline?
