Team Associated F1 >
Team Associated F1
Like Tree331Likes
Team Associated F1
Old 04-05-2017, 10:36 PM
  #301
Trader Rating: 14 (100%+)
Anyone else find that the kit setup ends up way off on ride height? I built mine as manual shows and my ride heights were around 6mm in the rear and 5.5 in the front. Anyone else close to those at kit settings?
Blues Hockey is offline
Old 04-05-2017, 10:56 PM
  #302
Kevin CBR's Avatar
Originally Posted by liljohn1064
The 13 and 14 will work. The Montech 17 should also work. I believe the Montech is what XRAY use in their kits.
The Protoform F1-13 body will not work well with the Associated front wing. The F1-13 is a "high nose" body and there is no attachment for the Associated front wing to support the high nose body. Would need to change to the Protoform or Tamiya Ferrari F60 front wing to work with the 13 body. The Protoform '14 and '15 bodies are both low nose and will work with the Associated front wing.
Panda
Kevin CBR is offline
Old 04-06-2017, 06:35 AM
  #303
I ran a 13 on mine while I was waiting for a 15, mounted up just fine.
MReggio13 is offline
Old 04-06-2017, 08:22 AM
  #304
MachineMan12's Avatar
Its nice to hear the kit comes with a template to cut out the front suspension! Do any other F1 kits do this?
Honestly, after building the CRC FC16, any kit with better instructions would be nice. That's how I would justify the higher price of this kit. Plus its from a mainstream company, it should be easier to get parts.
MachineMan12 is offline
Old 04-06-2017, 09:12 AM
  #305
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Panda
You're right, it's not ideal with the front wing. You could leave enough lexan on the front end instead of trimming right at the cut line to compensate for the gap on the wing/body mismatch.
liljohn1064 is offline
Old 04-06-2017, 09:27 AM
  #306
DARKSIDE's Avatar
I missed that?...where can you post a pic
DARKSIDE is offline
Old 04-06-2017, 09:35 AM
  #307
Toypainter's Avatar
Trader Rating: 110 (100%+)
I built mine per the instructions and with CRC rubber tires, ride height was almost 9mm! I ended up making a 2.5mm cf plate and using shims to get it down to 4mm.
Toypainter is offline
Old 04-06-2017, 09:46 AM
  #308
It's on the sticker sheet. I missed it too, but haven't started the final cut on my PF15.
MachineMan12 likes this.
Old 04-06-2017, 09:47 AM
  #309
DARKSIDE's Avatar
ok cool
liljohn1064 likes this.
DARKSIDE is offline
Old 04-06-2017, 10:43 AM
  #310
Billy Kelly's Avatar
This is only 3rd kit build for me. But I've taken apart and fixed more then a hundred. Build instructions are not what I would call good so far. Maybe it's just a few steps. But making slow progress.
Billy Kelly is offline
Old 04-06-2017, 12:29 PM
  #311
I made a template from my Tamiya F60 out of some spare lexan. A template for the rear pod would be nice too but hey, can't have everything.
viking44 is offline
Old 04-06-2017, 02:36 PM
  #312
That's a nice touch.
DavidNERODease is offline
Old 04-07-2017, 08:17 AM
  #313
Trader Rating: 50 (98%+)
I finally got mine completed last night. I will get to run it tomorrow and compare it to my previous chassis. Can't wait to see what it will do.
micrors4guy is offline
Old 04-07-2017, 09:18 AM
  #314
I'm really looking forward to racing against these at my local track - we need more exciting chassis diversity. F1 is a fantastic class.
Old 04-08-2017, 10:48 AM
  #315
jeppesen's Avatar
Has any of you a picture of the battery taped in the car?
jeppesen is offline
