Best 1/8th Scale Platform for Speed Runs
Hey gents,
I'm looking to build an 1/8th scale car for speed run purposes. Does anyone have any recommendations on a preferred platform?
I'm looking for a platform that has good parts support and is able to accept aftermarket ESC's and motors without too much special modification to the chassis.
Hey gents,
I also have a Kyosho GT2 and the Mugen is much better in every way I can think of. I have never had a Serpent Cobra GT but I know they are very good in quality but the parts are not as available as the Mugen or Kyosho.
I think a 977e is a much better choice, due the low weigh, low CG and easy to install 2x 3S or 2x 4S batteries.
977 e, arc 8.0e, motonica, Edam razor...
Foam tires and an unprepared roadway are a bad combination unless you add a lot of downforce, which you don't want to do for a speed run.
Why not the Traxxas??
While the XO-1 has the ability to be fast. The stock tires are terrible. Only real option is going with 1/5 tires. Had mine for almost 3yrs and never been above 70-75mph. Recently installed 1/5 wheel adaptors. Just need to buy another set of tires.
The 977e is a great 1/8 pan car but is limited in gearing. You will not be able to gear one of these very high. It would be better to convert a 977 nitro to brushless which will provide much more gearing options. But I think the OP was refering to 1/8 GT cars and not 1/8 pan cars?
I still say the Mugen MGT7 is the best 1/8 car for speed runs. Here is a vid of mine doing 159 mph and then 160 mph on 8s:
https://youtu.be/q5mN-X49v10
I use this car as a daily basher and weekend speed run car. Very consistent and reliable, it is the best car I have ever had with no weaknesses.
I did see a movie with a GT speedrun with an exploding tire. That is a problem with rubber tires, they baloon and then explode.
you can look serpent cobra gt e, mugen, hobbytech or even teamC for a gt 1/8
