Old 12-16-2005, 04:07 PM   #1
Trader Rating: 39 (100%+)
Send a message via AIM to Zac R Send a message via MSN to Zac R
Default orion element ???'s
has anyone had any luck with a orion 19turn?
and what do you gear like a c2 or a ready?
thanks
92zero Designs - AKA - O.S Engines - Futaba - Team Orion - B-Fast R/C LiveRC.com - RC Scoring Pro - TFR
92zero Deisgns
Decals - Clothing - Pit boards - Wraps - Signs - Banners & More
Zac R is offline   Reply With Quote
Old 12-16-2005, 04:20 PM   #2
Superkarter's Avatar
I got one from BRooD at It's an awesome motor. U have to gear it to the moon compared to other motors. I am running 39mm of rollout when people with cameleon's are running 31mm of rollout.
Superkarter is offline   Reply With Quote
Old 12-16-2005, 04:32 PM   #3
how many teeth higher than a c2 or a ready ?
thanks
92zero Deisgns
Old 12-16-2005, 04:46 PM   #4
Mr. McGoo's Avatar
i have had some pretty good luck with my Orion - i have found it is a little more efficient than my C2 or Reedy....
From what i have found you will gear it up most likely2-3 teeth from your C2 and maybe one tooth less than the Reedy (which I have found you have to gear to the moon to make it come alive - i am not a motor guru, but this is what i have found to work the best for me...
XRAY | RCAMERICA | HUDY | Team Tamale
Mr. McGoo is offline   Reply With Quote
Old 12-16-2005, 05:17 PM   #5
STLNLST's Avatar
Trader Rating: 21 (100%+)
thanks
iF YOU ARE GOING ASPAHLT NON FOAM GO WITH A FINAL DRIVE RATIO OF 5.5 IF IT'S A ROLLOUT WITH FOAMS GO WITH 36MM. I HOPE THIS HELPS YOU SOME. IF YOU HAVE ANY OTHER QUESTIONS I'M SURE SOMEONE ON HERE WILL BE MORE THAN HAPPY TO ANSWER ALL OF YOUR QUESTIONS.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-16-2005, 06:55 PM   #6
Matt Howard's Avatar
always yelling
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-16-2005, 08:35 PM   #7
TEM
TEM's Avatar
I'd say screw ratios and go with rollouts. You can't get screwed with rollout cause it applies to any size tire. Rubber tires also vary in diameter but no one cares about that.
Anyways, assuming it's the element spec 19, yes, as above 2-3 teeth bigger pinion than the C2.
TEM is offline   Reply With Quote
Old 12-16-2005, 08:56 PM   #8
AdrianM's Avatar
2-3 teeth higher to start with a regular endbell Element. If you have a V2 element you need to get some sprint edge brushes and some stiff MR springs and gear it up an additional 2 teeth over the regular element.
Adrian Martinez
Old 12-16-2005, 10:14 PM   #9
thanks guys
92zero Deisgns
Old 12-18-2005, 08:07 AM   #10
quantum's Avatar
"MR springs"?
quantum is offline   Reply With Quote
Old 12-18-2005, 08:12 AM   #11
Marc Rheinard springs, the bonehard springs that comes standard in MR edition v2... I didn't know you could buy them separately?
Morrissey is offline   Reply With Quote
Old 12-18-2005, 03:20 PM   #12
Rod M's Avatar
been speaking to guys in Europe who use this motor quite often,
they say to use the hardest springs you can get your hands on with the enduro (non edge) brushes.
TOPRACING.NET.AU Australian Importer of:
T.O.P. Tokyo Hobbies Optional Parts,
Team Trinity , BL Motors and Tyre compound
Team Tekin , ESC's, motors,
Elangears, Chargers,
Rod M is offline   Reply With Quote
Old 12-18-2005, 07:12 PM   #13
Yes you can: http://www.stormerhobbies.com/cgi-bi...umb=on&smode=0
you will need the ORN41387
cvt01 is offline   Reply With Quote
Orion Element Laydown? MonkeyNuts Electric On-Road 8 11-12-2007 03:52 PM
Orion V2 element motor oakesy2001uk Electric On-Road 16 04-28-2006 07:44 PM
would an orion element armature fit a orion core stock can? bionictony Electric On-Road 5 01-19-2006 10:32 AM
Orion Element V2 19T micros_rock Electric On-Road 40 04-28-2005 09:15 PM
Orion 19T element Brian Miskolczi Electric Off-Road 4 02-17-2004 02:53 PM
