Old 12-16-2005, 06:08 AM   #1
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Default gp 3700 mactedh vs IB3800 un matched
i been thinking of getting one of these to but a friend sudgested that i buy the 3800s coz there better etc etc.
i need help
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is offline   Reply With Quote
Old 12-16-2005, 06:37 AM   #2
stiltskin's Avatar
Trader Rating: 102 (100%+)
From what I've read on here, the 3800's are better cells. However, if they are unmatched, there's no way to tell what you're getting. I would think that the matchers sell the lower numbers as unmatched packs.
stiltskin is offline   Reply With Quote
Old 12-16-2005, 06:41 AM   #3
Matched IB3800's should be cheaper than matched GP3700's anyway.
Jack Rimer is offline   Reply With Quote
Old 12-16-2005, 07:57 AM   #4
Trader Rating: 22 (100%+)
Send a message via AIM to 5thscaleracer
both cells are good if you ask me. The IB3800 you will need to match them to know which are good and bad. I have been matching about 200 of the IB3800 cells in the past week, and out of the 200 batch i had only about 60 or so were pulling real good numbers the rest was avg.
i have about 8 cells which pulled bad numbers like 1.15-1.16 run time was great but just no power.
Avg volt i have been getting out of the IB 3800 and even the IB 3600 is 1.180-1.193 the good cells are pushing 1.197 to 1.24.
On the GP3700 i have been getting more consistent voltage numbers out of the bulk. out of a 200 cell batch the lowest number is 1.173 all were good (must have gotten lucky) nothing registered lower than 1.170.
The highest numbers i got out of GP3700 was 1.193 i have yet to see a 1.20 out of a GP cell.
All in all i don't think one is more superior than the other if i were to buy unmatched cells i would put my money on GP. If i were to buy match cells, then i would buy which ever has the highest numbers.
some testing info.
Matcher CE 4/35
Zapper Xipp
all discharged @ 30A
Charge @ 6A
cut @ .9
run time at 5000
FYI: those wanting to match batteries it's TIME CONSUMING!!! not to mention expensive.... i don't reccomend it!
5thscaleracer is offline   Reply With Quote
Old 12-16-2005, 08:18 AM   #5
Trader Rating: 16 (100%+)
When your friend telling you to buy those unmatched 3800.......how much are they actually cost..? Because if you are planning to spend like $50 for a good matched 6 cells GP3700...........on the return, you can spend like $35-40 for a un-matched IB3800 which is MOST LIKELY are NOT going to be better then your $10 more GP3700 (power and capacity BOTH)....
Now a day...unless your friend can hook you up a 6 cells IB3800 unmatch for $25......I would not think about unmatch packs. I brought some GP3700 matched from Brad at HURRICANE MOTORSPORT 1.18 for $45 (6 cells).......20 years ago, I think I paid $100 USD for Sanyo 1300 SCR Yellow matched 6 cells packs.
Oh...almost forgot to ask, you are racing or just running around with your friend....? If you are not going to RACE at all....voltage and amp and watt or matched no matched, zapped not zapped....DOES NOT matter....
Old 12-16-2005, 08:20 AM   #6
good point!!! not to mention
IB3600 unmatched $3.60
IB3800 unmatched cells are $4.40ea
GP3700 are $5.30ea this is the cheapest i have found so far.
Old 12-16-2005, 08:36 AM   #7
Send a message via AIM to David Alberico Send a message via Yahoo to David Alberico
MAtching doesn't matter anymore on bot accounts (3700's, and 3800's) there is no memory in the cells anymore and most vendors guarentee a minimum avg. voltage, as part of good QA.
Castle Creations, J-Concepts, WMD Products, Clints Creations
David Alberico is offline   Reply With Quote
Old 12-16-2005, 09:38 AM   #8
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Shows how much you know about batteries...
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 12-16-2005, 10:18 AM   #9
That is a bold statment...........
Old 12-16-2005, 01:11 PM   #10
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
The matchers are going to put the best cells into the $ packs. Whatever cells that dont perform are going to go into a stick pack so they can ge ttheir money back from their initial investment in the cells.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 12-16-2005, 05:41 PM   #11
veecee's Avatar
Trader Rating: 34 (100%+)
some testing info.
Matcher CE 4/35
Zapper Xipp
Charge @ 6A
cut @ .9
run time at 5000
Were these numbers achieved after zapping?
veecee is offline   Reply With Quote
Old 12-18-2005, 03:09 PM   #12
Well allow me to clarify. Since this is an on-road thread, for those looking for the best batteries and cost is no object, matched "cream of the crop batties" is what you are looking for, I guess around $80 to $100 per pack. But based off the GP 3300's I have gotten in bulk this past year I have been very impressed with the quality, QA and consistensy of the cells. I would have to say based on numbers and actual driving that unmatched cells but together and just run rank up with your average hobby shop battery pack. My cost per pack last year was around $23 dollars. And again, unmatched packs are perfect for off-road racing, of modified sedan, I do see the need for the matched best of the best for on-road 19T and stock.
Old 12-18-2005, 04:30 PM   #13
UCHEATULOSE's Avatar
Talking
dave when you threw your touring car at superior hobbies and it smashed into 50 pieces did one of those pieces fly off and hit your head?
UCHEATULOSE is offline   Reply With Quote
Old 12-18-2005, 04:36 PM   #14
car throwing is bad...
Joe Cude
Old 12-18-2005, 06:03 PM   #15
Jack2's Avatar
very VERY bad ...mmmmkaay......
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Matched 3300 and 3700 battery packs J.M. Australia For Sale/Trade 1 05-05-2008 06:54 AM
8 reedy realtimeIII 3700 matched batteries chuckharrisjr R/C Items: For Sale/Trade 0 04-18-2007 02:09 PM
3700 MAH MATCHED 4 CELL PACKS LOSIMANJRXS R/C Items: For Sale/Trade 16 05-02-2006 05:19 PM
Trinity Brand New Matched 3700 4 Cells x 3 Vegetto Australia For Sale/Trade 1 04-08-2006 06:05 PM
7x Six cell gp 3300 s & 3700 s most MATCHED Got Xray? Australia For Sale/Trade 5 03-23-2006 04:42 AM
