Old 12-15-2005, 01:25 PM   #1
maximebeauvais's Avatar
Trader Rating: 6 (88%+)
Default how to dead short ?
could someone explain me how to dead short a battery?
resistor? diode?
THANKS
maximebeauvais is offline   Reply With Quote
Old 12-15-2005, 01:38 PM   #2
MATTS's Avatar
Man, Email mo pour des question dememe !
M.
MATTS is offline   Reply With Quote
Old 12-15-2005, 01:45 PM   #3
GET READY TO DUCK IF ITS A VIRGIN IB 3800 DONT DO IT !
pony klr is offline   Reply With Quote
Old 12-15-2005, 01:46 PM   #4
MATTS's Avatar
LOL
Old 12-15-2005, 01:47 PM   #5
Registered User
losirunner's Avatar
Send a message via AIM to losirunner Send a message via MSN to losirunner Send a message via Yahoo to losirunner
ok, i dont reccomend dead shorting, but some swear by it. The times i have done it, I run the pack till a crawl, then put it on a tray to kill all remaining power. Then, solder a wire from the pos to the neg side, and let it sit for a few hours/days/ whatever. MAKE SURE ALL THE POWER IS GONE b4 you do this.
Then, when you know u are racing again, take the wires off about a day ahead of time to let the cells voltage equalize.
Then GO FOR IT!
losirunner is offline   Reply With Quote
Old 12-15-2005, 02:35 PM   #6
Super Moderator
Trader Rating: 17 (100%+)
suck the pack down to zero volts, attach wire to both positive and negative ends, put pack away. Race day...un attach wire and begin charging immediately. cells are already equalized...they are at zero remember watch out for false peaks. this will usualy happen early if its going to happen.
Tekno|JConcepts|TeamTrinity|BOOMrc
Bob Barry is offline   Reply With Quote
Old 12-15-2005, 02:54 PM   #7
right now I have built a discharger with resistor 0.12 ohms at 10 watts for every battery but after around 1 hour I still have some volt.
BTW this is for GP1100 batteries (xray m18 batterie). no discharger exist for those batterie.
someone said to put some diode or led to it?
I will post a picture of it later tonight (when kid will sleep!!!)
Old 12-15-2005, 03:04 PM   #8
some pictures. I hope that you will understand better.
Old 12-15-2005, 06:13 PM   #9
PitCrew's Avatar
If you fully charge the pack first, not only are you dead shorting, but you can Zap your cells at the same time.
no really, I'm just being funny.
PitCrew is offline   Reply With Quote
Old 12-15-2005, 08:30 PM   #10
to properly dead short a pack...there must be a slight amount of voltage on it. I would use a indiviual cell tray. After you discharge at a higher amp rate...put the pack on the tray till the lights are dim but not totally out, around 3 volts total for the pack. When the pack is in this area, attach the wire and all the bulbs should go out, signaling it is deadshorted.
I wouldn't recomend this for the IB cell, they don't react very well with deadshorting. But GP 33's and 37's, they gain a great amount of voltage and punch, but lose runtime. I have all my GP cells deadshorted and they perform extremely well.
Dhartman03 is offline   Reply With Quote
Old 12-15-2005, 10:00 PM   #11
Joel Lagace's Avatar
MAX ill try to help
What max is asking is what is needed to make a discharge tray that will bring down individual cells down to zero volts. Like some of the integy trays and the novak. A straight resistor is not bringing the cells down to zero. What is missing on his discharge tray that he is attemping to make for our MICRO sized 2/3A cells like the IB1200 and GP1200. The cells are dirt cheap and we really dont care about how long they last. We just want a kool 1/18th sized dead short discharge tray.
Any help out there?
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 12-16-2005, 02:07 AM   #12
You take hacksaw and saw through each cell. Now you have a battery that's made of cells that are both dead and short. Don't have much use for dead battery though. Don't mind me I'm today.
andsetinn is offline   Reply With Quote
GP 4300 dead short? FricFrac Electric On-Road 5 07-15-2006 10:18 AM
Dead short question for novak smart tray fat500 Electric On-Road 3 03-19-2006 12:42 AM
Integy Zero 6s dead short/ equalizing trays Mr. Shookie R/C Items: For Sale/Trade 16 11-03-2005 04:26 PM
Novak Flatline Dead Short 6-Cell Discharger Snikkari Electric On-Road 34 10-30-2005 05:53 PM
Why should I dead short my Ni-Cds? DennisNyholm Electric On-Road 8 03-18-2002 11:05 AM
