Like Tree126Likes
Tamiya TA07 pro
Old 11-28-2017, 12:43 PM
  #1456
Teamrule's Avatar
Great, thank you. I am thinking of starting for black carpet VTA with the sways, 55T spur 28T pinion, for FDR of 4.0, Motor in position one.
Unsure as to what weights to start with in shocks and differentials for oils. Maybe 3000 front diff and 1000 rear Asscoiated diff fluid, as that is what I have at moment.
Shock oil 50wt. I realize there is no one answer to all this but if I am way off feel free to chime in.
Teamrule is offline
Old 11-28-2017, 02:46 PM
  #1457
Never run thicker diff oil in the rear unless you want a drift car.
3000 rear is ok, 10000 front is quite free but you will get a lot of turn in but lose speed on the exit.
Qatmix is online now
Old 11-29-2017, 06:50 AM
  #1458
Teamrule's Avatar
Yes, i am thinking 3000 front, 1000 rear.
Teamrule is offline
Old 11-29-2017, 07:12 AM
  #1459
PIIHB!'s Avatar
What have you guys upgraded your ball cups/studs to? My stock cups and balls are worn out. I’m trying to avoid Tamiya replacements due to the slop and the fact the hardened studs with the 2mm hex are $10 for 5.
PIIHB! is offline
Old 11-29-2017, 10:18 AM
  #1460
JLock's Avatar
Originally Posted by B. Santos View Post
You use the shorter black ball cups included in Part #42281 to attach the vertical sway bar holders to the front arms. See part circled in red. This is illustrated on Page 20 of the TA07 manual.
Yes, the ones you have circled. The balls on the TA07 front arms are small so the gray ones (the ones below the circled ones) will not work.
JLock is offline
Old 11-29-2017, 07:42 PM
  #1461
Teamrule, I would try it stock and work from there. I was expecting to do a lot more tuning on my mine but everyone at the track was telling me just to drive it. It was good for a tq and good main battle and hasn't seen a camber gauge yet.
Syxxstring is offline
Old 11-30-2017, 07:37 AM
  #1462
Teamrule's Avatar
Yes, I forget many times best to start stock and make one change at a time. Did you literally build to manual spec and fluids etc.?
Teamrule is offline
Old 11-30-2017, 05:38 PM
  #1463
Yup, I didnt even put a camber gauge to it after setting the ball cups with dial calipers. I think I put thicker front diff fluid in and set the ride height/droop.
Old 12-02-2017, 06:25 AM
  #1464
Teamrule's Avatar
What position did you put motor in for black carpet?
Teamrule is offline
Old 12-02-2017, 08:00 AM
  #1465
My motor is in the middle but I'm on grey carpet till the track moves and we go to black.
From what I read here, it seems like middle will be the way to go.
Old 12-02-2017, 02:31 PM
  #1466
Teamrule's Avatar
Just to be clear when you say "middle" you mean farthest forward position as in middle of car correct?
Teamrule is offline
Old 12-03-2017, 07:10 AM
  #1467
Yes, I have my speed control behind the motor. I have a space between the servo and motor where I have a cooling fan.
Old 12-03-2017, 07:38 AM
  #1468
I'm really happy with the TA07 replacing my TA05V2R who served me well the last years during the Tamiya Cup in Belgium.
I've started with the same setup for black carpet using Tamiya Type-A tires:
parameter: front - rear
ride height: 5,0 - 5,5
droop: 6 - 5
spring: yellow - yellow
stabi: medium - medium
damper oil: 450 - 450
diff: 300.000 - 2000
camber: 1,5 - 2,0
Currently, the car is setup with Carson Cup Machine motor for club races and training. The shorty saves some weight while the Left/Right balance seems correct. I've ordered a NSX-GT 2005 lightweight for the coming season.
alwin is offline
Old 12-06-2017, 10:48 AM
  #1469
mgr
Have any one tried to mount damper towers in the rear from a TRF model?
i would like to try it so the body mount holes line up a little better if i wanna try diffrent bodies.
mgr is offline
Old 12-06-2017, 12:55 PM
  #1470
JD Skyline's Avatar
droop: 6 - 5
camber: 1,5 - 2,0
Thanx for sharing your set up!! Wil have look at it for the dutch Tamiya cup hahaha And drive already the same NSX body... Love driving that NSX
JD Skyline is offline
