Tamiya TA07 pro
#1171
Some ESCs can be configured to only use the sensored operation for low RPM and switch to sensorless for high RPM, but that's not how ROAR approved blinky operation works.
#1172
Why would you want a motor to switch to sensorless operation at high RPM anyway? Does it actually run smoother or faster without the sensor? I thought the whole point of sensored motors was they run smoother and more efficiently because the ESC knows the exact position of the rotor at all times.
#1173
If you want more top speed, make the pinion bigger or make the spur smaller; if you want more torque, make the pinion smaller or make the spur bigger. You don't need a chart to tune gear ratios, and it would be useless anyway because whoever would make the chart wouldn't know what motor you're using. This is a hobby; do some trial-and-error.
#1174
I'm running at 17.5t. I guess you're right, I probably won't get that rip out of the 17.5t, but I saw others at TamiyaUSA run 17.5ts and they seemed way faster than my setup. I'll learn, I'm still new at electric, used to nitro with 2 speed trannys, but electric is another world, very fun world though.
#1175
Trader Rating: 89 (100%+)
#1176
I am running 80 spur/43 pinion. Hobbywing Justock XR10 ESC paired with a Hobbywing V10 G2 17.5T motor.
#1177
#1179
Ta07, aka the plastic fantastic, tq + win in our Jackson Club Spec TC class.
+ YouTube Video | |
#1180
+ YouTube Video | |
Care to share the set-up?
#1184
What amps are you all running on your motors?
#1185
