Like Tree357Likes
Tamiya TA07 pro
Old 05-17-2019, 01:10 PM
  #2206
team green's Avatar
Exotek bulkheads installed. Car is 6 grams lighter with these bulkheads as opposed to the Eagle Racing bulkheads. Also blue looks so much better.
team green is online now
Old 05-18-2019, 02:15 PM
  #2207
Default Rear traction
Hi!
I have problems with my rear end and need som input on what is wrong?
The rear end feels very loose when entering corner, and it is quite nervous in middle corner. Ive tried with both rubber and foams on my local asphalt track. Griplevels is between low and medium due to the season. With foams (capricorn 26mm 32shore) it usualy produce alot of grip, but it still feels loose.
My car:
TA07R
Kit springs (progressive)
2 Degree camber all around.
CFR Chassie, bulkheads and stiffeners
Carbonplate mid sektion (mid-rear stiffener)
350CST shockoils front/rear
5000cst reardiff.
About 5.4mm front and 5.6mm rear rideheight with 1mm droop height.
Stock shockpositions, arms, hubs and armmounts.
1282grams with battery, without body.
Im running 4.5t MOD with 7.22 FDR, i also had the problem when i ran 8.5t. I know that there is a lot of power with 4.5t, but since it mostly feels loose on off-power it shouldent be becouse of the motorpower.
It feels like the car is without twist. It feels very planted for the most of the time. The chassi is extremely hard, the other drivers have xrays and their chassis feels very flexy, it think that might bee a big problem with my car, do you think i should change to the original chassie? I usualy have grip problems with going in the corners, but otherwise i keep up with my clubs other drivers with xrays. I usualy hit the breaks just before the corner to use the weightshift.
GBGTias is offline
Old 05-20-2019, 06:55 AM
  #2208
dmcguire's Avatar
Trader Rating: 30 (100%+)
What is your front diff setup? If you're running a spool up front, try going to a diff with heavier oil, maybe 20-30k to start. That should get you headed in the right direction.
dmcguire is offline
Old 05-20-2019, 07:03 AM
  #2209
Johnn27's Avatar
Trader Rating: 82 (100%+)
Default Suspension Mounts
Originally Posted by GBGTias View Post
Hi!
My car:
TA07R
5000cst reardiff.
What suspension mounts are u running Fr & Rr ?
Johnn27 is offline
Old 05-20-2019, 07:10 AM
  #2210
R/C Tech Elite Member
Marcos.J's Avatar
Trader Rating: 205 (100%+)
way too low if running a diff in the front ,for asphalt spool is the way to go
Marcos.J is offline
Old 05-20-2019, 10:11 AM
  #2211
Hi!
i use a spool in front and kit suspensionmounts.
I think its
FF = 1B
FR = 1B
RF = 1A
RR = 1D
GBGTias is offline
Old 05-20-2019, 12:20 PM
  #2212
Johnn27's Avatar
Hi!
I think its
FF = 1B
FR = 1B
RF = 1A
RR = 1D
try this suspension setup if you can it works for me running exotek conversion , short shocks, spool in front on asphalt and carpet
FF = 05F
FR = 05F
RF = 1XA
RR = 1E
Johnn27 is offline
Old 05-22-2019, 12:52 AM
  #2213
C van der Hagen's Avatar
FF = 05F
FR = 05F
RF = 1XA
RR = 1E
Make sure if you want to use the 05F-05F blocks in the front, that you use the 419x front arms as the hole for the shock in the 419x is too much inside, its made for the G-G blocks.
G-G , F-F, E-E with 419x suspension arms
D-D , C-C,... 419 front suspension arms
C van der Hagen is offline
Old 05-31-2019, 03:31 PM
  #2214
Hi!
My car:
TA07R
5000cst reardiff.
Firstly, your chassis is too stiff. Soft chassis is for low traction and stiff chassis is for high traction. You have made your chassis as stiff as possible!
Secondly, you want to change the front/rear balance so make the rear softer (springs and sway-bar) and with lower roll-center. The opposite for the front.
Thirdly, you want more weight transfer to the outside tires to increase grip on a low traction track. To do this you can narrow the track width, lower the roll-center and raise the center of gravity. The opposite of what you do to fight traction roll.
Also try a little less toe out-on the front to smooth the turn-in and a little more toe-in on the rear to add stability. If you end up with mid-corner understeer you've gone too far.
Good luck!
nubs and jgil089 like this.
CeeGee is offline
Old 06-07-2019, 01:31 PM
  #2215
Is the TA07 pro a competitive car on black carpet, compare to say x-ray, etc?
)EIB( is offline
Old 06-07-2019, 01:37 PM
  #2216
If I'm not driving it, and it's got a carbon chassis. I can confidently say yes.
Nerobro is offline
Old 06-07-2019, 01:52 PM
  #2217
we've got a guy at our club that turns laps as well as anyone else with his TA07. it's not kit and he's put a lot into it to get it where it is, but it's fast.
in my experience, the XRay, Associated, ARC, etc are going to be faster out of the box and easier to make faster still. seems like you pay up front with the other brands and later on with tamiya hop ups.
team green likes this.
JoshuaRC10 is offline
Old 06-07-2019, 02:14 PM
  #2218
What are some of the must have hop ups needed for this car to make it competitive with other brands? Is there a carbon chassis option for this car? I thought you would topically want a stiff chassis for black carpet. Is aluminum chassis option available?
)EIB( is offline
Old 06-07-2019, 02:47 PM
  #2219
team green's Avatar
You can get the Ta07 ms or you can get a Exotek conversion. PSM also has a conversion. Itís so happens I have one for sale.
PSM chassis conversion for Tamiya ta07 pro with aluminum bulk heads
Old 06-07-2019, 10:46 PM
  #2220
I can vouch for the PSM chassis. The last race at windy city, one of the mod guys was running a Exotek chasiss, and was fast.
There's carbon plastic arms available, and knuckles, you want those for black carpet. Thankfully, the arms are a whole lot cheaper than x-ray.
Nerobro is offline
