Like Tree488Likes
Tamiya TA07 pro
Old 03-02-2018, 08:57 AM
  #1561
nubs's Avatar
Originally Posted by Tom1977
Plus aluminium servo holder. The stock plastic one is too soft and crap.
I agree with this. The provided serevo mount had way too much give.
nubs is offline
Old 03-02-2018, 08:38 PM
  #1562
Originally Posted by nubs
1) You have the ability to fine tune the shock position
2) The plastic shock towers bend which create unexpected give in high speed turns
I run the standard TRF shocks and shock towers, not the SSBB. The SSBB are great shocks once you learn to build them but I don't find them necessary on the TA07. I run the TA07 on low-med grip asphalt so I don't need a super low center of gravity. But honestly, If you want to use the SSBB, go right ahead.
Thanks that makes sense. I'll add those to the list then for when (if) my lap times are getting consistent.
jgil089 is offline
Old 03-05-2018, 05:56 AM
  #1563
fat500's Avatar
Trader Rating: 51 (100%+)
the 07r uses 1b " b" blocks in the front as opposed to the 07 pro using "A" blocks.
what does this do? is it wider or narrower?
fat500 is offline
Old 03-05-2018, 06:56 AM
  #1564
Johnn27's Avatar
Trader Rating: 90 (100%+)
Talking
Widen the front, I am looking to try running F blocks in font on asphalt
Tamiya Suspension Mount Ultimate setting Guide and charts | The RC Racer
Johnn27 is offline
Old 03-12-2018, 08:41 PM
  #1565
MidwestRacer's Avatar
I am looking for a good starting point setup for Carpet. After getting smoked by one at TCS hobbyplex races I figured i had to get one. Thanks
MidwestRacer is offline
Old 03-14-2018, 06:31 PM
  #1566
Anyone.......Core Creations, care to chime in? you sir seemed to have yours dialed in Omaha TCS. Car looked awesome! My old TA06 with inboard shocks just could not hang with ya, but it still pulled a podium at least.
Old 03-14-2018, 06:35 PM
  #1567
Core Creations's Avatar
Trader Rating: 110 (100%+)
PM me your email and I’ll send you my setup sheet. Car had even more in it...which is scary. It was geared super conservative and it never really had to be pushed. That’s what this car does, makes it easy to drive fast if that makes sense.
You guys were able to pull a hell lot more out of those 06s than I ever could!
Core Creations is offline
Old 03-15-2018, 12:05 AM
  #1568
Originally Posted by Core Creations
PM me your email and Iíll send you my setup sheet. Car had even more in it...which is scary. It was geared super conservative and it never really had to be pushed. Thatís what this car does, makes it easy to drive fast if that makes sense.
Would you mind sending that to me too? I'm just starting out with the TA07 Pro and keen to see a decent setup
jgil089 is offline
Old 03-15-2018, 09:29 AM
  #1569
Yep... just PM me your email
Old 03-15-2018, 07:33 PM
  #1570
tboned_2002's Avatar
Tamiya TA07Pro - Mark Santa-Ines - Tamiya World Championship - Shizuoka - 19.11.2017
tboned_2002 is offline
Old 03-15-2018, 08:32 PM
  #1571
Johnn27's Avatar
Default TRF Short Damper Springs
What spring is the TRF black ???
Johnn27 is offline
Old 03-16-2018, 09:19 AM
  #1572
TRF - 42278
They fit the SSBB Shocks -
https://www.tamiyausa.com/items/radi...e-damper-42305
Old 03-18-2018, 06:52 PM
  #1573
Based on what I saw, 07 is more of an asphalt car right? seems like people are complaining about the flex in the chassis. If I want to get into the tcs racing at tqrc, will it better for me to stay with my ta06(has carbon fiber shock tower and reinforced bulkhead, gearbox ) and tb03 (literately has everything on it excluding the dcj , lucky enough to buy it from Bill at tamiya track for decent price), instead of buying a brand new ta07 ? The r version looks like a really attracting car...
zxcvb1t is offline
Old 03-19-2018, 05:50 AM
  #1574
The R version comes with the BB Damper. What spring sets can I get that fits?
airbiscuit is offline
Old 03-19-2018, 07:50 AM
  #1575
Tom1977's Avatar
R-kit has 4 super hard springs set (black), which is a special run from the original set Tamiya #42168. You also can run Tamiya BB-spring set (#42278/#42293) but then you need BB-spring retainers (14mm/#42192). Standard spring retainers in R-Kit are the 1mm up-type (#54776) which are only good for the old-type springs (13mm).
Therefore:
- Standard-R-Kit with the kit retainers: TRF spring set short (#42168)
- With new damper retainers (#42192): TRF BB spring set (#42278/42293) and all aftermarket BB-springs (SMJ/X-ray etc.)
DaSilva3525 likes this.
Tom1977 is offline
