Schumacher Mi6/Mi6 EVO >
Like Tree418Likes
Old 11-20-2019, 02:26 PM
  #1171
hi guys
anyone of you know where I can fin a U4910 alloy felx chassis for an mi6 or whatever other brand alloy chassis that can fit the car ?
thanks !
antho2b is offline
Old 08-02-2020, 05:59 AM
  #1172
Dxb430's Avatar
Default Out door evo setup with new shocks
Hello all,
struggling to get a decent outdoor base setup out doors for stock with the new shock setup. Tried Jordanís modified setup but the back end is too loose for 17.5t stock. Can anyone send me good starting point on a medium grip mixed track?
Thanks for any support
Dxb430 is offline
Old 08-02-2020, 10:17 AM
  #1173
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally Posted by Dxb430
Hello all,
try this one is for low to medium track but is with the old shocks but it should give you a good starting point
Schumacher MI6 Evo - Marcos Jennings - SS Raceway - 21.07.2017
Marcos.J is offline
Old 08-02-2020, 01:15 PM
  #1174
Dxb430's Avatar
Thanks Marcos,
will try try this but with the short shocks. Turns out the 3.0 that come with the short shocks are close to the shuie blues so will try both on my next outing
Marcos.J likes this.
Dxb430 is offline
Old 10-04-2020, 01:36 PM
  #1175
Looking for alloy chassis for MI6 if anyone has one they are willing to let go.
msimister is offline
Old 02-09-2022, 08:25 AM
  #1176
TheComeBack KiD's Avatar
Default Pinion Less play to spur gear I would try none
Originally Posted by The Teacher
Took my Mi6evo out yesterday for the 2nd time and I must say this car is awesome! I have the 2mm stiff graphite chassis with the low shock package setup on it and the car is money. One problem I've had with the car is that it strips gears almost every other run. I've checked everything in the drive train and everything seems free...I'm at a loss??? Anybody seen this, have any thoughts?
AJ, check your PMs man been trying to get some info!!!!
HI
Are you leaving a bit of play if yes I would leave as less as possible even none if might help
Thanks 🙏
TheComeBack KiD is offline
Old 05-15-2024, 02:28 PM
  #1177
MonkeyCmonkeyDo's Avatar
Running a mi6 outside on asphalt. Recommendations for front and rear Schumacher sway bar sets? Or just get the mi6 stock ones? Mi7 ones?
ty
-d
MonkeyCmonkeyDo is offline
Old 05-15-2024, 11:38 PM
  #1178
Robert K's Avatar
ty
-d
I would suggest getting the MI6 ones as the MI7's don't fit
Regards Robert
MonkeyCmonkeyDo likes this.
Robert K is offline
