Schumacher Mi6/Mi6 EVO >
Like Tree406Likes
Old 09-09-2019, 09:50 PM
  #1141
ImacFanatic's Avatar
6° caster blocks...
anyone using them, i never see that box checked on a set up sheet but wondering when and if you are finding them helpful and how they effect steering. Looking for more sterring with VTA on asphalt, also considering going with the low split blocks up front to drop roll center.
thanks.
ImacFanatic is offline
Old 09-10-2019, 03:03 AM
  #1142
The Teacher's Avatar
Trader Rating: 57 (100%+)
ImacFanatic, the 6deg caster blocks are like any other option parts...something to use for tuning the car. For me I use them when I want more mid to exit steering. Not saying this the only thing people use them for but this is how I use them. Best thing to do is go to your local track and do back to back testing with 4 and 6 degree blocks. You will learn first hand how they make the car feel to you when compared to 4deg blocks.
ImacFanatic likes this.
The Teacher is offline
Old 09-10-2019, 12:56 PM
  #1143
Hello all can anyone share with me the instructions for the short shock conversion kit. I snagged a second hand set with no instructions and want to completely rebuild them before testing
Dxb430 is offline
Old 09-11-2019, 09:03 AM
  #1144
eR1c's Avatar
Let us know how you like them once you get them installed, and if lap times improve. I've been on the fence about getting them.
eR1c is offline
Old 09-12-2019, 04:42 AM
  #1145
Here you go!
terminator_2 is offline
Old 09-14-2019, 01:21 AM
  #1146
Originally Posted by terminator_2 View Post
Here you go!
that is fantastic thanks. Needed the part numbers for the o rings and the caps cause these are vented
Dxb430 is offline
Old 09-14-2019, 01:28 AM
  #1147
Just noticed the part numbers are not on the instructions are the o rings fairly standard or do I need certain ones which swell with shock oil?
Dxb430 is offline
Old 09-14-2019, 09:56 AM
  #1148
The O-rings sold with Schumacher kits are usually bad, but I can't give you an answer for the ultra short kit.
I've tried TRF o-rings, it was better but the shocks still leaked, and I now use MuchMore Flex 40° o-rings, they are perfect smooth operation and absolutely 0 leak. I always use the shims provided with the shocks, and I put o-ring grease as well.
TeamRacing80 is offline
Old 09-14-2019, 01:53 PM
  #1149
So i can get an Mi5 evo for like 100.00
worth it for a back up VTA ride or pass?
looks like parts are still out there for it
Old 09-14-2019, 03:19 PM
  #1150
No9
No9's Avatar
Trader Rating: 16 (100%+)
They are larger than the standard shocks.
No9 is offline
Old 09-14-2019, 03:20 PM
  #1151
No9
No9's Avatar
I would jump on it, i still run mine any chance i get and parts support is great.
No9 is offline
Old 09-14-2019, 03:29 PM
  #1152
No9
No9's Avatar
The ultra short shocks still leak and i have had issues with them sucking in air through the bladder, to solve this i used a .03 diff shim between the shock collar and top cap to create a tighter seal on the bladder to shock body. Hope this helps anyone else having the same issue.
No9 is offline
Old 09-15-2019, 02:19 PM
  #1153
just so so I am clear is this at the bottom of the shock body and the .03 is in addition to the 2 shims in the instructions?
Dxb430 is offline
Old 09-15-2019, 02:33 PM
  #1154
No9
No9's Avatar
No at the top between the shock top cap and threaded collar. I used diff bearing shims to compress the bladder to the shock body and create a tighter seal.
No9 is offline
Old 09-17-2019, 01:07 PM
  #1155
Thanks that makes sense. I will give them a run out Sunday if it isn’t raining then see if air is getting in.
No9 likes this.
Dxb430 is offline
