Schumacher Mi6/Mi6 EVO
#1111
kobiwan, there are a few setups that will work on black carpet. I would recommend getting the 2mm stiff weave chassis, the ultra low short shocks/towers and the low roll center blocks. These parts will wake the car up and give it the steering you will need. I like to start with Elliot Harper's setup from DHI - Odense...found on www.petitrc,com
#1112
#1113
Super Moderator
http://www.racing-cars.com/pp/New_Ca...evo/U7327.html
#1114
Kobiwan, I've run both on high bite black CRC carpet and had the most success with the graphite chassis. The alloy chassis will help keep the car from traction rolling but will take away a lot of steering and makes the car heavy. The graphite keeps the car lite and will allow for more steering....something about its flex characteristics...
#1116
Cant help with the weights, but recently saw on Facebook that Schumacher made a post about their prototype chassis is being run in the BRCA Touring Car Nationals. Results werevery good in Mod and 17.5 Blinky.
The only thing I can see in the photo is what appears to be a dynamic rear toe setup.
#1118
Schumacher always seem to go their own way. They really dont seem to follow the "let's do what everyone else does."
I've owned a bunch of them over the years on and off road cars. They are always different then everyone else.
#1121
Has anyone had issues building the ultra short shocks? I have built them as per instructions and at first they feel great but after they have been on the car over night there is air in them. There is no leaks and all four shocks make that all to familiar squeak when compressed, the standard shocks never had any issues.
#1122
No9, I've had a problem in the past were I thought I had air in my shock but turned out that the piston was rubbing against the shock body. Take the shock off the car, remove the spring and make sure it's actually air in the shock. Question, is did you drill your shock cap so that the air can vent? Is the shock cap tight on the shock body?
#1123
#1125
I totally agree, does anyone know any option parts from other brand as yeah racing or other that can feet standard spure ?
