What products are you looking forward to in 2006?
#76
Originally Posted by EddieO
Brushed........stock motor, we'll see.
Bobby J, while there is a slight increase in cost....its not that bad....the arm is maybe 15% more from sagami.....the winding is a little more difficult of course, but its not too bad...
However, the motor runs cooler, longer, with way less maintenance....the brushes take a beating and keep running......with a v2 or checkpoint endbell....the motors that are getting 20+ runs could go double that with the 5 or 7 segment arms and neo mags.....let us use bigger arms and the power will be even greater.
The money saved in the long run on rebuilds will easily make up for the addtional intial cost......the same arguement used with brushless all the time....
Problem is.....ROAR promised a rules update (Rick Wilson, I have the email some where).....but they did not. And really, without IFMAR behind it....nobody is gonna do it until that happens......its why I stopped even working on it....
Later EddieO
Later EddieO
IFMAR is on the brushless bandwagon. This is a diffrent solution to the same problem. The good thing is Novak and LRP should have BL tear dowsn for sale soon.
#77
They are segments.....a motor has two poles, a north and south....
Bobby J, around 15% more overall over the current stuff....
I still think we could get it pushed through ROAR.....but it would retarded for us to use motors all year and then not be able to use them at worlds or at international events outside the USA....
Later EddieO
Later EddieO
#79
3-pin Deans Brushed/Brushless connector.
#80
Adrian ...
Is that what a brushless looks like out of the can ?
I`v gone over 200 runs with my Neo & still hav`nt had to open it up for maintenance......
Kool to see whats inside....
