Old 11-07-2002, 12:40 AM   #1
TRF-Powered's Avatar
Default Help needed!! Please reply fast! Thank you
Hi,
I would like to know why is it that when charging the battery the thrushold voltage between Ni-Cd and NiH battery are so different? Also, why is it that this method is used to detect the full charge of the battery? Why not just use the make the charger recognize the very peak of the pack, instead of having it check for the sudden drop in the pack?
thanks for all replied
TRF-Powered is offline   Reply With Quote
Old 11-07-2002, 01:55 AM   #2
Alvin's Avatar
because different packs will peak at different voltages?
Alvin is offline   Reply With Quote
Old 11-07-2002, 02:06 AM   #3
Im2lazy's Avatar
The reason why it senses for a drop in voltage is due to the battery 'not allowing' those volts to be put into the battery. Its like feeding the battery until it starts puking up loads of volts (gross reference huh.) The reason why we can't stop batteries after it starts to drop just a little, the closest to its peak is b/c the pack may be old and have more resistance (I know its something else; help me) and if you were to cut charging as soon as the voltage began to drop, the battery would not be fully peaked.
Im2lazy is offline   Reply With Quote
Old 11-07-2002, 07:00 AM   #4
university_dave's Avatar
Default Re: Help needed!! Please reply fast! Thank you
Originally posted by TRF-Powered
Hi,
Thrushold? I've heard of pigeon fancying but that is just ridiculous...
So far as I am aware the voltage actually continues to rise as you charge the pack, so you can't detect the peak itself.
university_dave is offline   Reply With Quote
Old 11-07-2002, 10:37 AM   #5
Ok it's quite simple, Ni-CD cells aren't as stable while charging as Ni-MH cells. So if you where to watch the battery charge on a digital voltmeter that can read out to .001 volts you would see Ni-CD's go up a little, slightly go down, go up some more.....ect.. where Ni-MH cells you wuld almost need a voltmeter to read .0001 to see as much activity during the charge.
Now some Ni-MH cells rspond tobeig a little more over charged than others... for instance----
Most 3000's like a delta peak between .003-.005 per cell....
Where 3000HV's prefer a delta peak around .007-.009
And most Ni-CD cells like .013........
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 11-07-2002, 09:47 PM   #6
rough512's Avatar
Originally posted by Im2lazy
...and if you were to cut charging as soon as the voltage began to drop, the battery would not be fully peaked.
I don't know much about NiMHs but Nicads exhibit a small voltage drop at the start of charging, after which the voltage just starts increasing. Some chargers start charging with 0.1C for a few minutes to work around this voltage drop, then starts hammering the battery with the full charging current.
rough512 is offline   Reply With Quote
Old 11-08-2002, 02:05 PM   #7
Why even PEAK. I charge my 3000HVs at 7 amps. I watch the mah on my charger, and when it gets to about 2.4 or 2.5 I cut it off manually. (2400-2500 mah) Then right befor the race, I charge again for about a minute, just to warm them up a little. I never let them charge all the way to 3000 mah. They would get too hot. When I have cycled the batteries like this on 20 amp light bulbs, with a volt meter. the voltage is incredible. It will stay above 7 volts till about 4:15. For stock racing that is great. I have found the same thing with my 2400s....cut them off around 2200mah and WATCH OUT!!!!
Pit Crew is offline   Reply With Quote
GM V12 Set-help needed fast!! rayhuang Electric On-Road 4 09-16-2007 11:25 AM
dyno needed really fast!!!! mountaindr3wz R/C Items: For Sale/Trade 0 11-01-2005 10:03 PM
Fast help needed on Integy Starter box Tom G Nitro On-Road 3 05-25-2004 08:00 PM
ESC needed fast Tragic Thoughts R/C Items: Wanted to Buy 9 02-22-2004 06:36 AM
help needed and fast TRF-Powered Electric On-Road 8 08-30-2001 04:05 PM
