Old 12-08-2005, 10:41 AM   #1
Default Need Help Making a 19 Turn Motor
At our local track we are starting to run 19 turn spec, but I cannot get a 19 turn motor locally. I did find a 19 turn Chameleon armature and wanted to put it in a Monster Horsepower Stock can with bearings from a mod motor. When I was put the motor together it seemed very slow.
I am using new stock brushes (Reedy 767) and have shimmed the motor to reduce play. I have tried purple springs on both sides and tried green red spring combination.
I am assuming that this combination of a stock can and 19 turn armature should work. Has anybody done this in the past?
Is there anything that I am missing to get this motor to run faster?
Any advise would be greatly appreciated.
Thanks in advance.
Mulligan Stu is offline   Reply With Quote
Old 12-08-2005, 10:50 AM   #2
Lou Decruss's Avatar
chamelon arm is a hemi wind.. meaning it runs in reverse polarity.. if you put in in a monster can your timing is negative 27 degrees. and it is retarded your motor is slow because its at -27 degrees.. did you notice you had to solder on the leads backwards so it will rotate in the right direction?
have your lhs order you a motor or you can put the chamelon arm in a mod can and adjust the timing that way.
to be "legal" you need to get a locked can 19t motor..then everythings matched up.. the don't cost much more than a stock motor..
where you located.. ? you can always order through an online hobby supplier like stormer, tower or bruckners.
Lou Decruss is offline   Reply With Quote
Old 12-08-2005, 11:28 AM   #3
EddieO's Avatar
R/C Tech Charter Subscriber
Regardless of its hemi wound or not.....as long as its spinning in the correct direction, it will be running at 24 degrees (not sure where you got 27) advance.....whoever made up this stupid myth about it retard timing is nuts....
The reason it runs backwards is that stock motors are crosswrapped, which requires the magnets to be in the can different than a modified motor....however, timing still is advanced or retarded in the same direction with the endbell, as its based on rotation, not the magnet configuration....
There are many 19t motors to choose from, we sell all of them at www.teambrood.com
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 12-08-2005, 01:36 PM   #4
Thanks for the responses.
So I guess all I have to do is switch my pos and neg to get the proper armature rotation and I should be fine.
Thanks again.
Old 12-08-2005, 11:51 PM   #5
I believe that the magnets in a monster stock are weaker than in a 19turn motor so your motor will be slower than a normal 19t.
Right Eddie O?
Charles is offline   Reply With Quote
Old 12-09-2005, 11:51 AM   #6
Switched the pos and neg and it made a huge difference. The motor is turning the right way and fast.
Thanks for all you help guys.
I know that it will slower than a 19T motor but it faster than a stock motor. Until I can get a 19T motor it will have to do.
Old 12-11-2005, 11:33 PM   #7
EddieO's Avatar
The 19t magnets are better.....the stock magnets are ppowerful enough, they just don't resist demagnetization as well, hence why they need to be rezapped....
Later EddieO
www.teambrood.com
i was looking for warp4 2 turn motor. instead i bought a ALIGN 430L motor rasserie Singapore R/C Racers 8 10-24-2008 11:14 PM
3 checkpoint 19 turn motor lo (money motor) $30 shipped for all johnny boy R/C Items: For Sale/Trade 3 06-17-2008 07:46 AM
Whats the fastest 19 turn and 27 turn stock motor? adr3naline fix Electric On-Road 104 08-26-2005 11:03 PM
Making A Decal For A Motor J Smith Electric On-Road 2 05-18-2003 11:22 PM
Making a 23t motor go fast fastolfart Australian Racing 45 03-04-2003 01:34 AM
