Old 12-08-2005, 05:00 AM   #1
noline's Avatar
Default Why do people disconnect there power caps in 4-cell 1/12th onroad
I noticed that the Top guys in Mod 4-cell 1/12th scale road course disconnect there power caps Is there a reason for this or do you not need one in 4-cell Modified Im currently running Mod w/ 9t and 8t motors w/ IB 3800's Batteries and a Novak GTX speedo I have no problem making run time I was just curious why would they disconnect the power cap any help would be greatly appreciated
noline is offline   Reply With Quote
Old 12-14-2005, 11:02 AM   #2
bump ?
alien too is offline   Reply With Quote
Old 12-14-2005, 11:05 AM   #3
Aluma's Avatar
well, powercaps are used to keep full power to the motor at all times. without it, you have a little lag from the time the juice comes from the battery to the motor...I'm guessing its for traction control? If power comes on too soon you'd lose traction, thereby losing speed.
Aluma is offline   Reply With Quote
Old 12-14-2005, 11:11 AM   #4
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
Hi,
You might get more response posting to the 12th scale thread.
I don't run a cap or a diode or anything like that. As I understand it a diode helps the brakes be more efficient and keeps the brake fet running cooler, I don't use brakes so I have no need for that. I'm told the cap helps to smooth the voltage out to the motor giving more punch. I don;t really buy this, I tried it and it doesn't feel like it makes any difference. Also I think to achieve this you would need a HUGE cap to have an effect. Also I do not want the extra wieght. I run mainly stock and 19T
Chris.
crimson eagle is offline   Reply With Quote
Old 12-14-2005, 11:35 AM   #5
The power cap is there to help the FET's switch on faster. Generally, adding the cap will give more punch because it allows the FET to switch on all the way faster (also more efficient). Some of the guys take the cap off if they have problems making runtime. Without the cap, the FET doesn't switch on as quickly and you use less power.
I really don't see a need to remove the cap with the new cells because there is so much runtime. Getting the car to work is more important and has a bigger effect than the cap does.
Unregistered is offline   Reply With Quote
Old 12-14-2005, 12:58 PM   #6
Charlie's Avatar
From my talking to folks, it's just a "room" issue. Not a lot of room for the cap.
But I still recommend that all Our Drivers use them for all applications. Regardless it improves motor response and helps the ESC operate more efficiently.
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Old 12-14-2005, 01:01 PM   #7
Oh, what do you know!!! LOL
See you in a few weeks Charlie!
walterhenderson is offline   Reply With Quote
Old 12-14-2005, 01:11 PM   #8
Hello Charlie,
I'am running a GT-7 now and was wondering if any damage will happen to the ESC if I don't use the shocky diode ??
Thanks,
Chris...
Grub_Maker is offline   Reply With Quote
Old 12-14-2005, 04:42 PM   #9
dakrat's Avatar
Originally Posted by Grub_Maker
Hello Charlie,
Thanks,
Chris...
most likely. its there for a reason
dakrat is offline   Reply With Quote
Old 12-14-2005, 06:50 PM   #10
Geeze.....know-it-all. Thinks he works at Novak or something.....
Graphitedust is offline   Reply With Quote
Power Caps & Schottky's ??? JohanZ Electric On-Road 4 03-16-2006 08:28 PM
Novak ESC & Power Caps ! macgyver1432000 Electric On-Road 1 03-11-2006 05:58 PM
power caps addicted2rc Electric On-Road 0 05-25-2003 04:26 AM
Power Caps nerdling Australian Racing 36 03-18-2003 01:39 AM
power caps was ist los? Electric On-Road 0 03-29-2002 11:36 PM
