how to stop a twichy front end on carpet >
Old 12-04-2005, 10:17 PM
tc3 racer sc's Avatar
Default how to stop a twichy front end on carpet
when running on carpet what can a person do to stop that twichy front end need help to solve the problem
1 go down/ up on droop
2.go in on shocks on tower or out
3.more caster or less
any info will help thxs
tc3 racer sc is offline
Old 12-04-2005, 10:24 PM
Moderator
Speedo's Avatar
Are you running a front swaybar? That would help smooth the car out.
Speedo is offline
Old 12-04-2005, 10:31 PM
yes i think i drive better on asphalt but want to get better on carpet
Old 12-04-2005, 10:35 PM
Moderator
Speedo's Avatar
Try taking some droop out of the front end.
Speedo is offline
Old 12-04-2005, 11:38 PM
Soviet's Avatar
Why not do it electronically with your radio?!?!
Dial in some negative exponential to soften reponse around center and decrease your steering speed some. Turn it down until you feel the car is mellow and smooth in the corners.
Soviet is offline
Old 12-05-2005, 02:51 AM
fathead's Avatar
Could try less toe out as well on the front, or some toe in
fathead is offline
Old 12-05-2005, 05:47 AM
Brandon Melton's Avatar
What's up Reggie, come see me this weekend, we'll get it straightened out for ya.
Brandon Melton is offline
Old 12-05-2005, 07:54 AM
teamgp's Avatar
In medium to high grip situations, softer front dampening will help the shocks absorb the direction changes more before the outside front wheel becomes loaded/planted as well.
More caster will also help the front end become more neutral steering as it increases the tendency to go in a straight line.
teamgp is offline
Old 12-05-2005, 08:50 AM
Trader Rating: 17 (100%+)
I can agree on that 150%.......I was a old time RC guy that used a old timer radio for my life untill 2 years ago switching to 3Pk and ignore all the feature of the radio..........thought my HAND and SKILL will do the work........WRONG.
Untill couple months ago a friend of mine tried out my 1/8th and wondering why my front end are so twichy after multiple setup of the front end with no luck (exactly like this case).......and found out I have ZERO SETTING of the entire radio (The only thing I did was the Max trim and other standard stuff, dont even know there is a ABS on these raido nowaday).........I don't even know what is negative exponential.......he set it to -40%.........I was like good 1.5-2 seconds faster per laps immediately after........
After that, I finally opened my brand new never opened 3PK manaul and try to learn/understand all those graphes and features..........
The worst thing about that is..........after all those years racing with others, I just realized I am the only one that DOES NOT have any negative exponential on the radio..........I am wondering what else that I have to know about radio setting.........GP or EP.
Solara is offline
Old 12-05-2005, 08:57 AM
teamgp's Avatar
My $0.02.
Using -EXP can definitely help. Just keep in mind that if you've been driving RC vehicles for more than a couple months, you're really masking a setup flaw when doing this though. If time is short, or you simply don't have the opportunity to work on setup, then it is definitely the way to go. But if you have the time and parts/tools needed, figure out the setup changes needed until you can put the radio EXP back to 0.
teamgp is offline
Old 12-05-2005, 09:02 AM
SOuthernFRIED's Avatar
Trader Rating: 21 (100%+)
1. bigger sway bar
2. less inboard toe
3. more caster
4. softer springs/ shock oil
or
5. bigger shock pistons
6. remove toe out or add toe in
Really the sway bar is the proper way to do it.
SOuthernFRIED is offline
Old 12-05-2005, 09:17 AM
Ali Graham's Avatar
BD was hard to drive with no roll (sway) bars with a front one-way on carpet. Medium front roll bar fitted, dialled.
Ali Graham is offline
Old 12-05-2005, 09:41 AM
ddesros2's Avatar
1. Expo first! Try it at the max setting, then dial it back till it turns good and fast BUT is not as twitchy. (Note: you can also mess with servo speed too).
2. Front sway. Only add after you mess with your expo.
ddesros2 is offline
Old 12-05-2005, 09:49 AM
Core Creations's Avatar
Trader Rating: 104 (100%+)
You could also try laying the front shocks down.
Core Creations is offline
Old 12-05-2005, 09:51 AM
Isn't that make the front end more grip...? At least that will get me more grip on the front when I do that....
Solara is offline
