LRP FLOW with x20 6.5 gearing >
Old 03-08-2016, 10:04 AM
Default LRP FLOW with x20 6.5 gearing
I wanted to know if anyone can help me with gearing for an LRP 6.5 motor for outdoors for a fairly medium sized track? I am going to be using it with a Flow Works team ESC.
thanks
Loheswaran is offline
Old 03-08-2016, 10:50 AM
swerv512's Avatar
Trader Rating: 17 (100%+)
I cant answer your question because i only run 17.5T but you may get more response by supplying the following:
type of car (pan car, TC)
model of car
type of tires (rubber, foam)
"fairly medium" might need to be justified with approximate dimensions "i.e. 200ft x 90ft"
ESC program- blinky or boost (mild, medium, max)
swerv512 is offline
