Need Some HELP plz! >
Need Some HELP plz!
Need Some HELP plz!
Old 12-04-2005, 06:55 PM
Default Need Some HELP plz!
So i just got a new radio( Blazer sport) and motor (trinity cobalt 10x2). When i hooked up everything the motor turned on i cheaked the trim and it was pefect. When i tried to pull on the trigger it stoped the motor instead of making it go. Then i switched the throtle switch to reverse and the motor worked perfectly. How do i make it so the motor will run with the trotle switch on fwd. I checked the wires too. My esc is a quantum competiton.
coolguy5 is offline
Old 12-04-2005, 07:17 PM
Charlie O's Avatar
Either you have the endbell with the timing marks on the wrong side of the motor, or you soldered the wires to the opposite polarity.
Charlie O is offline
Old 12-04-2005, 07:30 PM
scoobydo's Avatar
yeah, I would have to say the wires are on wrong. Usually, it is hard to tell the positive side of the motor can from the negative. The polarity marks are sometimes tiny. Then again, if you say you checked them....then I have no idea.
scoobydo is offline
Old 12-04-2005, 07:33 PM
danjoy25's Avatar
Trader Rating: 38 (100%+)
Reset all your radio trims to neutral and throttle channel must be in reverse and then reprogram you speedo again.
danjoy25 is offline
Old 12-04-2005, 07:47 PM
dakrat's Avatar
reverse polarity. sorry gotta laugh
dakrat is offline
Old 12-04-2005, 08:55 PM
Its not reverse polarity. I cheaked everything. Will i lose any speed runnning in the revers channel?
coolguy5 is offline
Old 12-04-2005, 09:00 PM
dakrat's Avatar
set your TH to reverse then reset your esc.
dakrat is offline
