Old 11-07-2002, 01:19 PM   #16
Trader Rating: 49 (100%+)
Send a message via AIM to weaponx
i run the setup up that the manual had out of the box for the414m2 with these exceptions. associated springs front purlple(30 pound spring) 80 weight oil. Rear associated spring blue (17 pound ) 35 weight oil. blue swaybar on front and rear.shocks in front located in outer most hole, shocks in rear mounted in middle hole. sorex 28s with hpi red inserts and a protoform dodge status body.the car has plenty of steering and the rear end is planted. hope this helps.
weaponx is offline   Reply With Quote
Old 11-07-2002, 03:48 PM   #17
Aurra Sing's Avatar
Try a front stabilizer. Also try mounting the rear shocks on a more inner hole, or front shocks on a outer hole.
Aurra Sing is offline   Reply With Quote
Old 11-07-2002, 03:55 PM   #18
rccarracer's Avatar
I would add a stabilizer, and add some more rear camber. I run 2 degree negative in the rear and 1.5 degree negative up front...
rccarracer is offline   Reply With Quote
Old 11-08-2002, 07:13 AM   #19
Vic
Vic's Avatar
First I will go with -1.5 front and rear and go from there.
What gear ratio do you Guys use on carpet?
Mine is 7.53 and it is fast and have punch too.
Vic is offline   Reply With Quote
Old 11-11-2002, 04:11 AM   #20
Vic
Vic's Avatar
Good news!
To me they were, I ended-up having -1 Camber front and -1.5 at the back and it seemed to solve my problem not only it was solved but I ended up 3rd at the race.
Old 11-11-2002, 04:30 AM   #21
KiwiKid's Avatar
Vic, glad to know that you have solved your problem. As for the negative camber setting - it is designed to give you more traction to the outside tires as your corner. This occurs because more weight is transferred to those tires and there will be some body roll as well. Hope that helps.
Originally posted by Vic
KiwiKid,
I always had the impression that if I have very little -camber, the tire would have more % on the ground.
If I would add more - camber means less % of the tire on the ground more slippery???????????
Help me I am fairly new to all this but I love to drive.
I only started this May.
KiwiKid is offline   Reply With Quote
Old 11-11-2002, 04:51 AM   #22
Vic
Vic's Avatar
Thanks it did help, on the other hand I am still thinking whether I should have more or less camber in the front compared to the rear and what effects does it have.
I would have another question toe-in in front does it help to have more traction at the rear going in or coming out of a corner?
Thanks!
414m/414m wcr/all o4's and similar design 414x and 414 imataquito Malaysian R/C Racers 983 01-22-2011 06:34 PM
txt-1 or 414m? ijnek Malaysian R/C Racers 6 10-13-2008 05:51 AM
414M Nielonsx Australia Wanted to Buy 0 02-02-2006 12:51 AM
414m NIB x414x R/C Items: For Sale/Trade 0 08-18-2004 12:39 PM
414M, MTX-2 Afro Puff R/C Items: For Sale/Trade 31 06-06-2004 09:26 PM
