Checkpoint 19turn spec mod
#346
well ive never had glitching probs because of mine. but if you are, and adding additional capacitors fixes it, by all means add them and run it.
#347
Originally Posted by CarKing
Has anyone had glitching problems with their money motor? I am running one and have always had some glitching issues at the end of a long straight. Has anyone had to add additional capacitors on the motor?
#348
I was running my money motor with infinity brushes and silver springs on both ends with a rollout of about 29 and after the run the motor got to about 138°F, and when I took the motor apart the comm seemed like it had been overheated, it turned to a purple color. This is running a TC with foams on carpet.
#349
#350
Just a regular IB 4200 pack.
#352
I have a quick question I could use some input on. I just cut the comm on my checkpoint and I'm replacing the stock atlas brushes with the infinity ones. I'm also going to go with the stiffer silver springs. However, the hobby shop hasn't got the silver springs in stock and I'm waiting for the springs to arrive. Is it ok to break in the new infinity brushes with the stock springs and then just replace the springs when the silver ones come in...or do I need to wait and break in the brushes with the springs that I'm going to be running (i.e. the silver)??? Thanks
#354
Location: Curacao, Netherlands Antilles, Dutch Caribbean
On both the T2 anf fk05 I use the Team Tamale fan mount with two novak fans.
Only issue I'm confronting is where to plug in my personal transponder.........
For a large asphalt track I'm running 4.93 on 38.23 rollout with 60 mm tires on the T2. I'm using the infinity brush with the stiff springs. Anybody know of any ill effects of this combo in 100 plus degree weather. Braking is quite the fireworks show in the car at times.
Don
Don
#355
BTW, you can also add a few motor shims (0.3mm-0.4mm) in between the brush and the spring and still use the stock springs.
#356
Originally Posted by teamgp
It should be fine to use the stock springs. I would suggest you break it in at 0.5v for 20 minutes with some comm drops. This will ensure the brushes break in without the comm getting heated, expanding and wearing much of a groove.
#357
Thanks for the input. So will adding the shims act just like changing to a stiffer spring?
#359
Originally Posted by AdrianM
Much More makes a "C" shaped brush spring preload spacer for the Check Point motors. You can add and remove them without unsildering the shunt.
#360
anyone have the part # for the brush spring spacers?
