Checkpoint 19turn spec mod
#317
Originally Posted by BSchorr
What kind of Rollout are people running with the Checkpoint for carpet? im like 27.5mm-28.5mm with a KD 19 turn. KD's are more of a rpm motor and CP19's more of a torque motor?
Today at a high bite large track (several slow/tight corners as well as two sweepers) with 56.0mm tires, the optimum rollout was 33.2mm.
#318
I'll be getting one of these motors in the next couple of weeks, and I plan to run a fan on the endbell using these (http://teammuchmore.com/product_info...roducts_id=424) to mount it. I'm just not sure whether the fan is 25mm or 30mm (it looks like a 25mm MM fan in the pic, but just don't what to get the wrong one). Anyone have any idea what size fan I will need.
Ben
Ben
#319
which current esc is set up to run the checkpoint 19t to its full potential
#320
Mine is the Keyence Rapida Pro.
#322
I'm a Novak / LRP fan.
#323
ive read that you can get an esc that is programmed for 19t motors i just thought some of you guys may use one?
ive tryed the novak gtx its a nice piece of kit!
#324
My endbell warped, is that possible from heating up the tabs soldering? I have my skottchy diode on the motor and it was being a pita to get off, I have the motor geared to 31ish rollout and it comes off the track around 150 so I don't think that's enough to warp it.
#325
I don't think 150°F would be enough to warp the end bell, but keeping a soldering iron on there will because its way hotter than 150°F.
#326
Anyone know how long the infinity brushes are new?
#327
Originally Posted by MikeXray
Actually I just took it apart, somehow I bent the timing ring, maybe tightened it with the tab not in the slot? I bent it back and it sits flush again.
#330
Ben
Ben
