Old 08-23-2006, 12:31 PM   #271
no help at all?
Matt
mat3833 is offline   Reply With Quote
Old 08-23-2006, 03:15 PM   #272
Originally Posted by mat3833
no help at all?
Matt
You'll probably be fine with the springs it comes with. The CP$ has more torque than you'll need for a relatively short track, such as yours. I've never run it on dirt but I can just imagine the roosters it could generate.
Stampede is offline   Reply With Quote
Old 09-18-2006, 07:24 AM   #273
Location: Curacao, Netherlands Antilles, Dutch Caribbean
Send a message via AIM to dogenia Send a message via Yahoo to dogenia
Default Temperature
Hey guys I have a question. I ran the Checkpoint this weekend with foams on asphalt in the fk05. I used the Team Tamale fan mount with two 25mm Novak fans mounted. Gearing was 116x40. The motor came off the track consistently @ 180F with no signs of fade at the end of the battery pack.
Is this good or bad? My mission in life is not to run the motor into the ground at one race but rather to promote the life of the motor.
I'm still experimenting here, but I'd appreciate everybodys input. The motor is ballistic, but i choose to err on the side of caution.
Don
Xray T2 in 19 turn spec class, Novak GTX, Sanwa M8
dogenia is offline   Reply With Quote
Old 09-18-2006, 07:41 AM   #274
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Don, assuming you're running your foams 58mm or less, sounds like you're right on track. If the car is carrrying good corner speed and your lap times aren't far off, then hang another tooth and see what it does.
BigDogRacing is offline   Reply With Quote
Old 09-18-2006, 07:50 AM   #275
Default another tooth
Ok sounds like a plan. Yes the foams are 58mm .My main concern was the temp is was coming off the track with. But now................ (mad scientist laugh) more speed, more speed, more speed. The car acts like it has a two speed. Somewhere mid track on the straight it just grows ............
Don
Old 09-18-2006, 10:23 AM   #276
mbunker's Avatar
Trader Rating: 29 (100%+)
Send a message via MSN to mbunker Send a message via Yahoo to mbunker
I have a question when re-shimming the CP $ and removing the rubber O rings. Should I place one of those larger diameter fiberglass type washers against the com side of the arm first to keep oil off the com then brass shims or is it unnessary because of it has bearings and not bushings like stock motors?
Thanks ~michael
mbunker is offline   Reply With Quote
Old 09-18-2006, 10:32 AM   #277
Why do you want to remove the o-ring? The o-ring gets rid of the slop without sideloading the bearings (if properly shimmed).
Corner Weight is offline   Reply With Quote
Old 09-18-2006, 05:19 PM   #278
mbunker's Avatar
To make the motor more effiecent. I removed the oring also because with it, the rotor wasn't in magnetically centered in the can.
michael
Old 09-18-2006, 05:21 PM   #279
mbunker's Avatar
When i took the oring out and put the motor back together to re-shim, it spun so much more free then with the oring in.
Old 09-25-2006, 12:34 PM   #280
TryHard's Avatar
errr.... anyone know if I can get just the endbell for a Money?
Had a really big crash (it also split the chassis, but not my fault) the other weekend, and have just found that it bent the negative nut and brush tube Would rather not have to buy another complete motor... but if thats the case, so be it.
Thanks in advance
Ed
| THard.co.uk | Xray | MuchMore |
Old 09-25-2006, 01:15 PM   #281
Send a message via AIM to ERTRACHTER
congrats to all the checkpoint team who made a mains at the iic and congrats especially to bobby flack for winning foam tire 19 turn class
ASSOCIATED 12r5.1,REEDY MOTOR AND BATTERY, LRP SPEEDO,KIMBROUGH PRODUCTS,BIG DOG RACING,BELMONT R/C SPEEDSHOP, DENNIS LYMAN RACING, TEAM TOSO, TEAM FACTORY BITTER, SCHUUR SOLUTIONS, SIMMONS RACING, TEAM BOOZCRUZ
ERTRACHTER is offline   Reply With Quote
Old 09-25-2006, 02:22 PM   #282
How did Bobby Flack gear the CP 19 in the IIC (rollout) - what springs and what brushes? Any other hints to get this motor to run faster?
duckman996 is offline   Reply With Quote
Old 09-25-2006, 02:38 PM   #283
i ran rubber tire so i dont know the rollout but it was infiniti brush and light springs im pretty sure i know mine was jason
Old 09-27-2006, 05:33 PM   #284
IN RUBBER TIRE I RAN A FDR OF 6:1
Old 09-27-2006, 07:36 PM   #285
Glowster21's Avatar
Trader Rating: 116 (100%+)
Silver springs, infinity brushes, roll it out around 32mm, HOLD ON TO YOUR A$$!!!!
This motor is as fast or faster than any Komodo out there and you don't have to tear it apart every run
Glowster21 is offline   Reply With Quote
Trinity Komodo PRO 19T or Checkpoint spec 19T t3amfish Electric On-Road 0 08-28-2008 01:56 PM
Sphere TC Spec,13.5 Duo,Checkpoint balancer,FT B4 HWYSHREDDER78 R/C Items: For Sale/Trade 6 07-31-2008 12:25 PM
2 fantom 19turn accorr spec handwound arms brand new jason cheng R/C Items: For Sale/Trade 22 05-20-2004 01:16 PM
19turn spec ZigZagRC Electric On-Road 2 04-18-2003 06:42 PM
Tuning a Motor and 19Turn Spec Suggestions Cain Electric On-Road 25 12-01-2002 06:34 PM
