Checkpoint 19turn spec mod >
Old 07-21-2006, 09:14 PM
  #226
Core Creations's Avatar
Trader Rating: 105 (100%+)
Originally Posted by Darkseid
Unfortunately, you know all too well what I'm talking about with the going through brushes. Well at least with those damn 767 brushes...
Sadly, yes
Core Creations is offline
Old 07-21-2006, 09:34 PM
  #227
polesitter61's Avatar
I tried the crazy tall gearing too and thought the same thing, too slugish. I ended up in the 6.40's on rubber tire TC on a 55x100 track with a full length straight.
polesitter61 is offline
Old 07-22-2006, 10:36 AM
  #228
ttso's Avatar
I run my Money first time today on asphalt track, using gear ratio 6.1 (about 32mm rollout). The motor is crazy high temp, after 8mins runs I got 80'c on motor can (50~60 on comm as I have fan and airflow deflector to cool down comm) and it still running with no sight of fade what a crazy stuff...
But I do find with 6.1 ratio the bottom is kind soft. But after middle it rocks. I gonna try 6.3~6.5 tomorrow in middle of race (lol.. 6cells Mod with 8mins.. I don't believe anyone with 8T can finish it without running out of juice. )
ttso is offline
Old 07-22-2006, 02:38 PM
  #229
Does anyone know what size the endbell screws are?
stuartb is offline
Old 07-22-2006, 03:30 PM
  #230
chris_morrison_'s Avatar
im gearing my money 19 at 7.0 on a track with a tight infeild and a 140foot straight.
chris_morrison_ is offline
Old 07-22-2006, 05:40 PM
  #231
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 93 (100%+)
Only think that is deturing me from buying checkpoint motors is the $10 brushes! What is the life on them? I know V2 motors have the Sprint Brush and the Enduro Brush. Is there only one kind for checkpoint?
BSchorr is offline
Old 07-22-2006, 06:31 PM
  #232
there is two brush types
the atlas brush $4
and the infinity brush #10
the infinity brush that is in my motor ha 15 runs on them and there still good.
Old 07-22-2006, 06:38 PM
  #233
BSchorr's Avatar
I can get Reedy 767's and F-brush's for $1.25 a pair, wonder if i should just use the KD19? Ill be using the 10x2 and 12x2 V2's in my offroad truck and buggy
BSchorr is offline
Old 07-22-2006, 09:10 PM
  #234
the k19 is also a good motor i gear it at 7.0 final and it makes tones of power with the epic 4499 brushes
Old 07-22-2006, 09:49 PM
  #235
Regional Moderator
Darkseid's Avatar
Do you mean what size the hex is? If so, the hex is a 2mm hex.
If you mean how long the screws are, not sure but I would guess something like 8mm.
Darkseid is offline
Old 07-23-2006, 10:54 AM
  #236
Sorry i wasnt very clear, i meant the length and size eg M3 etc.
I want to get some more but much longer to mount a fan.
stuartb is offline
Old 07-23-2006, 02:01 PM
  #237
2-Bad's Avatar
Trader Rating: 24 (100%+)
The brushes that are on the motor from factory are atlas brushes. I get around 7 or so batt. packs before I repack them. Haven't used the infinity brushes on this motor yet.
2-Bad is offline
Old 07-23-2006, 04:12 PM
  #238
Default INFINITY brushes on a CHECKPOINT 19T
BSchorr/2-bad
We have a Checkpoint 19T, fitted with Infinity brushes, that we run in touring cars on rubber tyres in the UK.
Today Ian TQd and won both A finals in the UK TORC series using the same motor all day without skimming or brushing at all. This same motor has TQd and won both finals at TWO previous TORC events at different tracks using the same brushes. All the motor gets is a skim after the event. Gearing is 5.35 or 5.19 depending on track.
Makes Infinity brushes look pretty good value to me.
As a comparison, we found last year that Atlas/C2/Corally motors needed to be skimmed and brushed (767)every race in the same conditions.
regards
Don
donwhit is offline
Old 07-23-2006, 06:53 PM
  #239
BSchorr's Avatar
donwhit- what about the V2 onroad motors and the sprint/enduro brushes
BSchorr is offline
Old 07-24-2006, 03:48 AM
  #240
BSchorr
We bought two 19T v2s to try.
Maybe we were too chicken with the gearing but we could never get them to go fast enough. If we geared high to get top speed then there was no pull off the corners.
I know lots of people praise the V2 but in 19T they are not beating us!
regards
Don
donwhit is offline
