Checkpoint 19turn spec mod
#136
Originally Posted by MR JOLLY
stuart is this post true
The C2, KD-19 turn and the Evo Zone 19 turn from Itegy are Mabuchi cross wrapped.
EA
#137
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Originally Posted by EAMotorsports
Yes Colin. A hemi wind will be about a half turn less than a Mabuchi. The Checkpoint motor, Reedy Quad magnet and the Blue Atlas are all Hemi wound motors.
EA
EA
#139
sorry Advil for questioning your post
think your self`s lucky
if you questioned some thing over here your get slagged off for asking
#140
Darkseid,
Stiffer springs (to me) seem to add RPM and take away punch.
#142
#143
No worries Jolly
Can't get mad at someone named Jolly. It wouldn't be right
Darkseid,
Darkseid,
#144
Stiffer springs increase RPM. Counter intuitive, but that's the way it seems to work.
I won't argue with STNLST tho, anyone who is able to rocket thru a solid pipe at the end of a straightaway must know something about horsepower.
#145
#146
Originally Posted by STLNLST
You know anyone looking for a spektrum set for the helios???
I gotta finish putting the car together then tune my motors. You have a money motor right??? I'll help you tune it up for this weekends race. What springs are coming on them stock????
#147
I just hope the weather cooperates so we can finally get some track time.
#148
No worries Jolly
i ask to many question`s you know
#150
Originally Posted by Bobby Flack
That to me seems the opposite. I always use a stiffer spring to get more bottom end.
At higher RPM, the stiffer springs (again - within reason) KEEP the brushes in good contact, overcoming vibration and any tendency for brush bounce, which would restrict the RPM peak...
Of course, it is possible to OVER spring, and in that case, the springs are so strong that they almost turn the brushes into brake shoes and the top end RPM range is reduced due to all the drag.
The key is to spring as strong as you can until you see the peak RPM limit start to drop and then back down one grade in stiffness. This is where a good dyno pays off, but track testing will tell you the same thing, just not as simple to test that way...
I have been able to confirm that the Silver "Medium/Hard" springs really make the "Money" motor HAPPY... I think the Atlas brushes are a bit soft for 19t offroad (softer springs "drag" more), but the motor runs so well, I'm leaving them in for now...
