Dead Shorting with Novak Smart Tray >
Old 11-30-2005, 09:03 AM
DustinR's Avatar
Default Dead Shorting with Novak Smart Tray
I have lost the manual that goes with my Novak Smart Tray and now I want to start dead shorting but don't know how with the tray. If someone can please confirm that this is correct I would be greatfull.
Do I take down to .1 per cell then put the tray in dead short mode and DS the pack.
Would i be correct that on race day in between charges I take down to .9 then recharge the pack and then after the day is done I DS.
Thanks for any help.
DustinR is offline
Old 11-30-2005, 09:14 AM
rayhuang's Avatar
Dustin, Unplug the power from the unit and then hold the black button while pluggng back in the power. Now the unit is in DS mode.
Just FYI-the unit doesnt truly deadshort a pack for you. It discharges it to zero then shuts off, then as voltage recovers-it discharges it again till zero and then turns off. So on off on off.
To truly deadshort you should use a the Novak Deadshort trays or an INtegy product made to do this.
Ray
rayhuang is offline
Old 11-30-2005, 09:20 AM
DustinR's Avatar
Default Thanks
Thanks for help Ray.
So will a DS wire across the battery do the same as the trays.
If it does can I put the wire across the pack after a discharge on the tray to .1 per cell
DustinR is offline
Old 11-30-2005, 09:23 AM
rayhuang's Avatar
I cannot recommend that. 0 volts then put a piece of solder across the battery. If theres voltage in cell-the solder will melt and no harm done.
rayhuang is offline
Old 11-30-2005, 02:30 PM
Mitropoulos Jim's Avatar
Deadshort trays are much better than a piece of wire across the
battery,because trays prevent the cells from being damaged,
as far as I am concerned.Otherwise,they both do the same job...
Good luck,
Jim
Mitropoulos Jim is offline
Old 11-30-2005, 08:38 PM
deadshorting cells either way has its ways of damaging cells....so why not go the cheaper route?
R/C Anonymous is offline
