Jaco Foam Tires
#16
Excellent reply
Korgae;
Great information, thanks from all of us for the research you did.
#17
Let me ask this question then...
What are the size of the wheels that come stock on the RTR TC3 kit? They look to me as if they are 28mm....but, the diameter of the wheel seems to be 2 inches. Aren't there 1.9 inch rims and 2 inch rims?
Once I know what the TC3 comes with stock, I will be able to buy my Speed Mind foams.
#18
here is what the SpeedMind website says about their foam wheels....
Ultra Performance Foam Tires
All SPEEDMIND Ultra Performance Foam Tires are mounted and trued on our unique German formula"K-28 IMPACT MASTER" Aero-dish white heavy duty wheels. .... getting the strength and flex on the foam tires.
Extensive choices to suit drivers of all skill levels, different weather conditions, car models and various track surface conditions. Using "shore" (foam density) as unit of reference, drivers can be more accurate in the selection of foam type for practices and big races.
3 tire widths : 26mm, 28mm and 30mm
5 foam shores : 35, 37, 40, 42, 45 (higher shores are recommended for outdoor racing)
It says they come in three different widths. I have the 28mm ones right now. They fit perfect on my Traxxas 4-Tec. But, they will not fit on my TC3. The axle is too big on the TC3, and the inside of the wheel rubs on the suspension.
#19
Trader Rating: 32 (100%+)
Hey guys sometimes the foam tires need to be narrowed up to fit some cars. When you put the tires on a tire truer take a file to the inside edge while its running to narrow up the tire so it clears all your suspension parts or if you have the room grind some materal away from where its rubbing. And with some of the tires not fitting the TC3 axle you might have to take a reamer to the hole of the rim and make it a little bigger because the TC3 uses american size axles and most rims are made for smaller metric axles.
#20
Thanks Korgae
I think your post answered all my questions and most others. I do like FOAM over rubber so I am glad to run it, just was a little anoying to have to adjust the rim for the car. Yet I will give them a wirl.
I think I will try your messurments of 28mm and 26-27mm. I know from experience that I prefer wider tires. Been a few years since we last ran foams.
Cheers
Cheers
#21
So you saying that the 28mm Speed Mind wheels that I have don't come in a different size to fit my TC3? No matter what I will have to make the hole bigger to fit the axles?
#22
unknown, the SpeedMind rims are metric, and are drilled out to fit a metric axle which is slightly smaller than your TC3 axles. All you need to do to make them fit is drill or ream the hole slightly bigger. As far as the inside edge of the rim rubbing, I've had the same problem before when using Jaco foams. Just do like Kevin said, after you're done truing the tire, just take a file and hold it against the inside edge of the tire/rim and it will narrow it a bit. Only go a little ways, and then check if it fits again.
#23
All right, well, I made the holes bigger and they fit perfect. But, the left front rim wobbles. Yet another problem!
#24
Unknown,
Those are your speedmind wheels and tires that wobble?
#25
yeah, one of them does. they are brand new too.
#26
To UNKNOWN
Unknown,
If you drilled your rims from the outside in, then there may be a small burr of plastic that is not allowing the wheel hexes to seat properly. Just use an X-acto knife to deburr the inside edge of each hole.
Once in awhile new rims are not true, but not often. Look for something in the hex mounting area of the car or rims.
#27
Problem fixed. Something was stuck in the hex on the wheel. I cleared it out...and all 4 wheels are on. Only thing I am worried about is the the rear wheels come really close to the suspension.
#29
sorry Mr. R/C Guy. I didn't know I had to answer to you before I posted. Give me your e-mail address and I will e-mail you before every time I post. Again, I am sorry, and it wont happen ever again.
#30
Kit TC3 wheels/tires
From what I have read in the reviews. I believe that the car comes with Pro-Line "V"-Rage (or clone) tires in a S2 compund, with soft open cell foam for inserts.
They really don't grip very well at all unless ran on a prepared track.
