Old 01-08-2006, 08:34 PM   #1426
BritRacer's Avatar
There were only 2 broken cars today. Me, and one guy who demolished the left c hub and left knuckle....it was a glancing blow on the boards....pretty high speed though, but would not have thought it would have done that much damage.......................
BritRacer is offline   Reply With Quote
Old 01-08-2006, 09:24 PM   #1427
Send a message via AIM to g_bruin Send a message via Yahoo to g_bruin
For those of you who are moving up from an '05, did you run with the motor guard and does it really protect the motor? I think it would provide protection against corner dots from the bottom...
I am moving up from an '04 so I am starting from scratch.
I have the T2 on order along with:
Multi-diff - Us So-Cal guys like our one-ways!
One-way Lube - Gotta keep the multi-diff working smooth.
Motor guard - Debating this...
Xray 30 wt shock oil - My LHS only sells Losi and AE oil and that bottle that comes with the kit is tiny!
87t 48p spur - One spur isn't enough and this is the largest that can be used without it hanging below the chassis.
g_bruin is offline   Reply With Quote
Old 01-08-2006, 09:37 PM   #1428
Company Representative
Trader Rating: 15 (100%+)
For anyone looking to play with the width of the T2 ( or have a issue with the how foams fit the front of the car) I came across this XRAY shim set that works better then planned.
Part # is 96 4030 ( Washer S 3.5x12x0.2 ) the inside diameter perfectly matches the threads on the axles with no slop the outside perfectly matches the hex. Each shim is .2mm thick so it allows you very fine adjustment with width putting one on each side increases the width by 1/2 a mm. 10 shims come to a pack.
take care
Korgae
WCICS- Competition Director
Korgae is offline   Reply With Quote
Old 01-08-2006, 10:33 PM   #1429
Twin-Kyle's Avatar
Originally Posted by BritRacer
you could look down the chassis, when the car was upside down, and see the chassis was twisted. Bad enough?
was a glancing blow on a board, not a head on hit.
To actually SEE a tweak in the chassis tells me that it had to be a much harder hit then a "Glancing blow"
I would also suspect that the car sustained more damage.
If the tweak is that bad...all you should have to do is relax the screws on the top deck and chassis then tighten them back up.
I will be surprised if you can get the screws loose with that kind of bind in the chassis though....
I pounded a guy with my 05 in Cleveland.When I tried to get the screws out of the top deck...the screws were actually seized in due to the bind.Had to cut the top deck off!!! Thankfully there was NO other damage.
As I said, I POUNDED the other car so some damage was to be expected.
Twin-Kyle is offline   Reply With Quote
Old 01-09-2006, 12:19 AM   #1430
for the T2 are you using the stock spring on the foams tire carpet set up. I will be get my t2 this week i am really lookiing forward to racing it
ptjonesus is offline   Reply With Quote
Old 01-09-2006, 05:20 AM   #1431
Rob Phillips's Avatar
Steve W, what's the word on the T2's?
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 01-09-2006, 05:44 AM   #1432
NOOB-SMOKE's Avatar
Default t2 spares
HELP!
Does anybody know where i can get spares for my t2 as i need a rear hub.
CHEERS!!!
NOOB-SMOKE is offline   Reply With Quote
Old 01-09-2006, 08:44 AM   #1433
Gael L's Avatar
How are you guys breaking in your diffs? Are you running them as they come and tightening them as they loosen up and break in?
Gael L is offline   Reply With Quote
Old 01-09-2006, 08:48 AM   #1434
TDO
TDO's Avatar
As with al new diff's or rebuilds I always run them in and them gently tighten them after each couple of runs/rounds.
TDO is offline   Reply With Quote
Old 01-09-2006, 09:12 AM   #1435
gonzo416's Avatar
Trader Rating: 39 (98%+)
Speedtech RC any updates on our T2 shipment, like when they are going to be shipped
gonzo416 is offline   Reply With Quote
Old 01-09-2006, 09:14 AM   #1436
Frank McKinney's Avatar
Going to start building my car soon, are there any tips from drivers who've raced theirs regarding the transfer of FK'05 setups to the T2? Just wondering if anyone has tried to 'match' their old setup and if this has worked, or if you've started fresh with the recommended setup from the included setup sheets?
TIA
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 01-09-2006, 09:22 AM   #1437
Scho's Avatar
Send a message via MSN to Scho
Got my T2 today
Scho is offline   Reply With Quote
Old 01-09-2006, 09:26 AM   #1438
teamgp's Avatar
Originally Posted by thebrad
How about the ball bearings? Are they mostly in the same sizes as the T1FK05?
Bearing sizes:
Qty...Size...Use
2...5x8x2.5...Ball Diff (each)
1...F3-8 3x8x3.5...Ball Diff (each) - axial thrust bearing
12...2.4mm...Ball Diff (each) - pulley bearings
10...5x10x4...Layshaft (2), Frt/Rr wheel hubs (8)
4...10x15x4...Frt/Rr diff hubs in the bulkheads
2...4x7x2.5...Servo Saver
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 01-09-2006, 09:30 AM   #1439
BritRacer's Avatar
TIA
Its pretty similar geometry wise, but springs/oils need changing.
Old 01-09-2006, 09:31 AM   #1440
BritRacer's Avatar
looking to get some ceramic bearings, who has the best price/quality for individual/pairs of bearings, just need some for the outdrives!
