Old 01-07-2006, 03:33 PM   #1336
Ill Factor's Avatar
Waiting on mine from Speedtech. I gotta say they are top notch when it comes to customer support.
ChrisP or teamgp: Did we get an answer on the possible chassis tweak problem when the car is set up with a medium or soft chassis?
Ill Factor is offline   Reply With Quote
Old 01-07-2006, 04:10 PM   #1337
Trader Rating: 42 (100%+)
Hey guys, i am building a multi diff for the first time and just read the directions where it said that you should put "one way oil" on the one way bearings.. Couple of questions:
1. what is one way oil
2. are they pre-oiled from the factory so i could put this together and use it or do i have to wait for some to arrive before using?
Not sure if this is off topic or not, if it is i apologize.
rccars4scott is offline   Reply With Quote
Old 01-07-2006, 04:19 PM   #1338
PaintingRoly's Avatar
Trader Rating: 56 (100%+)
Originally Posted by crisis641
looks like they already have a wider top deck for the car
http://www.rc50.com/modules.php?name...lbum=14&pos=89
this is from the Novak race up at Trackside.
Does anyone know if that wide upper deck comes with the US kits?
WOW!!! I was just looking at that picture and didn't notice that. It looks like a modifide FK05 top deck. maybe something made at the track to stiffen up the car.
follow me @RC3grafix on Instagram for pictures of my paint work.
PaintingRoly is offline   Reply With Quote
Old 01-07-2006, 04:38 PM   #1339
Trader Rating: 29 (100%+)
Does any one know whos car that is ?
Mdoc is offline   Reply With Quote
Old 01-07-2006, 04:50 PM   #1340
Ill Factor's Avatar
There goes the one chassis all conditions statement. Which for me is fine as I was worried it would be too stiff anyway. I would think that unless ur competeing nationaly that your not gonna be helped by just a wider top deck.
Old 01-07-2006, 04:53 PM   #1341
my computerscreen is not so good but the bodyshell is showing a name
Frans H is offline   Reply With Quote
Old 01-07-2006, 04:56 PM   #1342
Gael L's Avatar
To add to that...Does anyone know where I can get the heatsink and fan that they have on the motor?
Gael L is offline   Reply With Quote
Old 01-07-2006, 05:08 PM   #1343
Im gonna guess that all the fastest T2`s there have the kit top deck on them....thats why I wondered whose that was....
Old 01-07-2006, 05:30 PM   #1344
Killa that is a 3 racing heatsink/fan combo. You can get it from precisionrc.com (my spelling may be off) it's like $5 but shipping is $10+ He modded the way the fan is mounted and used a different fan
Old 01-07-2006, 06:04 PM   #1345
J@UNE's Avatar
white rear springs on foam?
J@UNE is offline   Reply With Quote
Old 01-07-2006, 07:19 PM   #1346
Dynamite's Avatar
Send a message via MSN to Dynamite
Thumbs up carbon motor protector?
hey Spillertwo, nice pics of you car.
i just finished building mine here in australlia too!
that carbon fibre motor protection brace pictured on your car, did you make that up? or is that a euro option thingy?
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 01-07-2006, 07:26 PM   #1347
BritRacer's Avatar
Ran one pack through mine today, and, well, WOW.
From the looks of that pic he's running a lot of spacers on the rear. a lot of toe in.....
BritRacer is offline   Reply With Quote
Old 01-07-2006, 07:31 PM   #1348
BritRacer's Avatar
oh, and carpet ready my arse.
You have to reduce the width of the fronts to stop them binding.
Old 01-07-2006, 07:43 PM   #1349
Trader Rating: 37 (100%+)
Says Mike Dumas.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 01-07-2006, 08:15 PM   #1350
Send a message via AIM to g_bruin Send a message via Yahoo to g_bruin
TeamGP - Can you tell me what size nuts are included with the kit?
I know I need to get a 7mm for the wheel nut. Is there any other size needed?
Thanks!
Originally Posted by teamgp
Here ya go:
Qty --- Description and size --- Use(s)
7 --- HEX SCREW SH M3x5 (button head) --- multi-diff (3), spur gear (3), front top deck (1)
43 --- HEX SCREW SH M3x6 (button head) --- fr/rr shock towers (8), rear upper deck (8), upper bulkhead clamps (8), quick roll center holders (4), front top deck (9), upper shock mounts (4), motor mount (2)
6 --- HEX SCREW SH M3x8 (button head) --- rear body posts (2), servo (4)
8 --- HEX SCREW SH M3x10 (button head) --- c-hub bottom (2), steering linkage (6)
2 --- HEX SCREW SH M3x12 (button head) --- rear outer camber link (2)
2 --- HEX SCREW SH M3x14 (button head) --- front outer camber link/c-hub top (2)
6 --- HEX SCREW SH M3x16 (button head) --- fr/rr suspension holders (4)
2 --- HEX SCREW SH M3x18 (button head) --- rear suspension holders (4)
24 --- HEX SCREW SFH M3x6 (coned) --- bottom chassis/bulkhead (16), alum deck stands (4), servo (2), battery backstops (2)
11 --- HEX SCREW SFH M3x8 (coned) --- bottom chassis/bulkhead (1), rear bulkhead brace (2), upper bumper brace (2), lower bumper brace (1), antenna mount (1), battery backstops (4)
4 --- HEX SCREW SFH M3x10 (coned) --- lower bumper brace (4)
If you plan on using lighter titanium screws, I'd suggest that you DO NOT replace the following:
* all screws mounting from the bottom of the chassis - you'll probably have to add weight to make the minimum requirement for rubber and foam rules, and adding it up higher would defeat the purpose
* all suspension holder mounting screws - the titanium ones will bend more easily in a crash and introduce tweak through differing arm geometries
If you plan on using steep camber angles with large shims under the outer links, then you'll need to switch the following:
* Replace the 2 HEX SCREW SH M3x12 (button head) with 2 HEX SCREW SH M3x14 (button head) for the rear links
* Replace the 2 HEX SCREW SH M3x14 (button head) with 2 HEX SCREW SH M3x16 (button head) for the front links
NOTE: The kit comes with the latest *black* coated screws which resist binding to the CF much better. As per the manual, we still suggest applying a thin layer of CA with a Q-tip to the counter sunk holes on the bottom of the chassis. Make sure you wipe away the excess CA from the flat surface on the top and bottom sides of the chassis.
g_bruin is offline   Reply With Quote
