Old 12-06-2005, 03:47 PM   #616
Trader Rating: 16 (100%+)
Old 12-06-2005, 03:59 PM   #617
AdrianM's Avatar
Lemieux won Cleveland with a 2mm chassis and a 2.5 top deck.
Adrian Martinez
Old 12-06-2005, 04:03 PM   #618
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Actually he said he went back to the 2.5mm chassis and 2.5mm top deck. But still....It proves that thicker isnt always better
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 12-06-2005, 04:12 PM   #619
imprsme's Avatar
Trader Rating: 74 (99%+)
EA
Thats not what Jessica said! LOL
Eric hate that you are not going to make the race this weekend.
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 12-06-2005, 04:37 PM   #620
Exclamation
All Chassis will be 2.5 MM There will be no need for 2 mm or 3 mm chassis or upper deck. The way X-Ray has designed this new car, is so that there will be no need for all the option pieces. It should still be similar in price to the fko5 but not need all the "normal" required items that the fko5 uses. Such as all the different thickness chassis for asphalt and carpet racing. The new car will have the multiflex system which Guy hood has described. As well as the different hubs for your offset, you also donít have to worry about having to buy the 30-5315 spring steel hubs because of "boogering" up the outside of the hub to get it out of the hub carrier. This means that the bearings in the hubs are much smaller which is a major advantage. It is a common 5 by 10 clutch bell bearing as used on the XB8. All of these reasons are improvments to help the car. So there were more than one reason for the new design, which uses the nut instead of the screw and washer.
Last of all, The car should be available early January to the public.
AJ Goin is offline   Reply With Quote
Old 12-06-2005, 04:42 PM   #621
Originally Posted by [email protected]
Rc America needs to quit ignoring the majoritity of U.S.A. racers, who run rubber tires on carpet and asphalt, specifically the West coast. The T2 should come with the multi diff, or at the very least give us the option to order the kit with it.
The majority of U.S. racers are carpet racers. %90 percent or more would prefer that it comes with two diff's instead of a diff and multidiff. If you consider that you have two diff's and then purchase a multidiff, you can use your extra diff for the rear when the other wears out.
Old 12-06-2005, 11:01 PM   #622
RCknight's Avatar
Default Looking at the pics...
it seems Xray designed it to break more arms. Man...those wheel nuts stick out there too far. I never broke an arm on my 05.
RCknight is offline   Reply With Quote
Old 12-06-2005, 11:21 PM   #623
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Anyone notice that there are two front towers bolted on in picture 11 from the zip file?
Speedo is offline   Reply With Quote
Old 12-06-2005, 11:21 PM   #624
Moderator
Speedo's Avatar
2 rear towers too - picture 12.
You can see it in a lot of pictures actually.
Old 12-06-2005, 11:54 PM   #625
centax error!'s Avatar
it's the lamination line that you're seeing.
centax error! is offline   Reply With Quote
Old 12-07-2005, 12:08 AM   #626
Moderator
Speedo's Avatar
Nay.
Old 12-07-2005, 01:27 AM   #627
RCknight's Avatar
Default Yea...
I noticed that it had two screws for the shock towers. They must of thought it was better. It makes sense to me. I'm trying to figure out where I'll mount my transponder.
Old 12-07-2005, 07:32 AM   #628
Michal101's Avatar
Nay.
It sure looks like 2 shock towers...the picture tells the story.
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Michal101 is offline   Reply With Quote
Old 12-07-2005, 08:10 AM   #629
P-DUB's Avatar
They will have a 1.8mm 2.4mm & 3.2mm chassis for the T2
Sup EA...He ran the 2mm for Cleveland, but will go back to the 2.5mm now Novak Race getting close....Maybe they will have a heat wave this year...LOL
Larry Pryor
P-DUB is offline   Reply With Quote
Old 12-07-2005, 10:21 AM   #630
Midnight's Avatar
Trader Rating: 85 (100%+)
When is the release date?
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
