Old 01-23-2007, 06:15 PM   #5836
slakr's Avatar
Trader Rating: 31 (100%+)
I bought a T2R and so did a buddy of mine. As luck would have it, I get to put them both together; which is cool because I enjoy it.
However, I am having a problem with one of the drive shaft/axles binding. Out of the eight I have assembled; seven of them work flawlessly smooth...
But no matter what I do I can't get one of them to not bind.
Any help or advice would be greatly appreciated.
Other than that, both cars have gone together great and I am very impressed so far with the kit.
slakr is offline   Reply With Quote
Old 01-23-2007, 06:28 PM   #5837
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Besides cleaning the bad unit and relubing, I could suggest checking the blades on the driveshafts. If they aren't on the pins properly or are disformed, this can cause the driveshaft to bind.
Good luck - I just built mine and I'm impressed before driving it
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 01-23-2007, 06:54 PM   #5838
MikeXray's Avatar
Trader Rating: 73 (100%+)
Do you mean the axle side or the blade diff side? If the axle side triple check that that pin is not sticking out one side at all.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-24-2007, 05:20 AM   #5839
slakr's Avatar
It is the axle side, but the pin is not sticking out of either side.
If I just hold the pin in place by placing a finger to each side; it moves freely in all directions.
However, once I tighten the grub (set) screw; it binds in one direction.
I.E. it will move freely left to right, but will bind when moving up and down.
-Tim
Old 01-24-2007, 05:26 AM   #5840
chach's Avatar
Did you maybe put too much thread lock on the set screw in the CVD, it may have leaked onto the pin and seized it up a little..
chach is offline   Reply With Quote
Old 01-24-2007, 06:28 AM   #5841
MikeXray's Avatar
-Tim
You may want to order a new sleeve and pin just for the heck of it, my kit came with 2 rear pins improperly machined, maybe its just a fluke.
Old 01-26-2007, 05:54 AM   #5842
rcdy's Avatar
i have Fk05 bushings #302290, will these things fit the t2? since the t2 bushings had a different part#. thanks
TeamXray, TeamAssociated, Esky, Tamiya
rcdy is offline   Reply With Quote
Old 01-26-2007, 10:02 AM   #5843
Nexus Racing's Avatar
The T2 uses the long-style bushing (like those on the FK05) only on the bottom of the C-hub...it has a short bushing for the top.
They will probably only fit the top of the T2 C-hub if you cut them shorter.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 01-26-2007, 05:13 PM   #5844
slakr's Avatar
Thanks to all for the advice.
I lightly filed and sanded the slots where the pin travels... it is better, but not perfect.
So.. I just went ahead and ordered the new parts.
Old 01-26-2007, 05:29 PM   #5845
STARSCREAM's Avatar
get back to work slakr!!!!!
Sean Maybell
Team Associated/Reedy/LRP
STARSCREAM is offline   Reply With Quote
Old 01-26-2007, 05:58 PM   #5846
Korey Harbke's Avatar
Maybe YOU should Maybell!!! Wait a sec... I probably should too
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 03-15-2007, 09:46 AM   #5847
mojoman's Avatar
Has anyone had a problem with the axles or one way clicking as you drive 100% left and right. It's as if the wheel has an inexplainable wobble. The plastic shims are between the outdrives and the housing. And the dogbones are straight. No bearings are shot. The action is smooth until steering linkage cranks to full left or right.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 03-15-2007, 10:12 AM   #5848
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Go here and this explains it.. And how to fix it...
http://nexusracing.net/newsdesk_info.php?newsdesk_id=40
Or here also....
http://forum.teamxray.com/viewforum....d71da3f5ca3b58
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 03-15-2007, 04:12 PM   #5849
MleedM's Avatar
Default Difference?
Quick quesiton, probably a long answer:
What is the major diffs between T2, T2R and T2 007.
T2R is FRP chassis right
T2 carbon fiber
007 the lower deck and all
Main question is are the diffs, shocks, drive train, control arms, etc all the same and interchangable? or are there more differences than the chassis plates?
MleedM is offline   Reply With Quote
Old 03-15-2007, 04:16 PM   #5850
wallyedmonds's Avatar
the 007 is old now
its time for something new.
wallyedmonds is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
dLRiom
