Old 10-17-2006, 01:36 PM   #5791
Din Viesel's Avatar
What is a good website to find after market parts for my T2? I am looking for rear alumn. hubs....I knew of a website (now forgot) that listed a lot of different manufacturers down the left column and you could click on each one to view as to whether or not they made up grades for your particular car or not!
If anyone knows what the heck I am talking about that would be great.
Din Viesel is offline   Reply With Quote
Old 10-17-2006, 01:40 PM   #5792
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default Alum parts
if you're going to get Aluminum parts, go with Team Tamale.
very durable (way better than Xray's bend-a-easy aluminum) and great fit and finish.
believe it's
www.TeamTamale.com
olhipster1 is offline   Reply With Quote
Old 10-17-2006, 01:58 PM   #5793
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Are you talking about ?
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 10-17-2006, 02:10 PM   #5794
rpoage's Avatar
XRA 303358
http://ashfordhobby.com/detail.aspx?ID=2263
Should get the job done for you.
rpoage is offline   Reply With Quote
Old 10-17-2006, 02:42 PM   #5795
Din Viesel's Avatar
believe it's
www.TeamTamale.com
Unfortunately I went to Team Tamale first and they are currently out of stock!
Old 10-17-2006, 02:45 PM   #5796
Din Viesel's Avatar
Yes, but I was looking for some other manufacturer, other than Xray.
I too heard they are kind of soft.
Thanks though!
Old 10-17-2006, 02:48 PM   #5797
theisgroup's Avatar
it is worth the wait. they are the best machined parts available for xray. they use the same bearing as as the stock plastic hubs and they don't bend.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 10-17-2006, 02:49 PM   #5798
olhipster1's Avatar
Default email
email
Larry at teamtamale.com, he's the owner and maker.
he might be able to tell you when his next batch is going to be cut...or he might have them but hasn't updated his website...not sure if gets time to update his webpage often.
I agree with theisgroup...i've had the TeamTamale stuff on my xrays...darn things are almost indestructible, he uses the best material out there.
worth the wait....you won't regret it.......also the alum steering knuckles with the ackerman are the bomb.
Old 10-17-2006, 02:52 PM   #5799
Din Viesel's Avatar
Thanks guys,
I will send an e-mail to Team Tamale and find out when they will have more!
Old 10-17-2006, 04:59 PM   #5800
stiltskin's Avatar
Trader Rating: 102 (100%+)
Thanks guys,
Hey Chan-lover, the Tamale stuff is the way to go. I bought the Xray knuckles and Tamale rear hubs. The only difference was the price hike for "Xray". I thought the Xray quality would be better based on their pictures but it just wasn't so. See ya at the track.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 10-22-2006, 11:37 AM   #5801
Default rear toe in
I've been going over my car for like an hour and can't figure out what my problem is. When I put it up on the set up board I have 2 degrees of left toe in and 3 degrees right toe in. Left side has 1L hub right has 1R hub. Same number of spacers on each side. Pins are straight. According to the instructions it should be 3 degree on both sides with the spacers I'm using. Any ideas? I have the bmi carpet chassis. Anybody have a similar problem? I'm tempted to used different spacers on each side but I feel something must be wrong.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
porschejim911 is offline   Reply With Quote
Old 10-22-2006, 11:43 AM   #5802
ChrisP's Avatar
Check to make sure that your screws for your hinge pin mounts are not bent..
ChrisP is offline   Reply With Quote
Old 10-22-2006, 08:44 PM   #5803
They look straight.
Any other suggestions? I'm gonna tear everything apart I guess but some suggestions of what to look for would be great.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
Old 10-22-2006, 09:19 PM   #5804
ChrisP's Avatar
The easiest way to check the screws is to monitor them as you tighten or loosen them...of the head stays centrally located ...then you're ok..if the head moves in a circle...it is bent and should be replaced.
Old 10-22-2006, 09:29 PM   #5805
Isn't this the same problem people were complaining about when the T2 first came out - unequal rear toe. Here is the "official" response from Xray about the issue. XRAY Announcement on T2 Rear Uprights.
dway100 is offline   Reply With Quote
