Old 09-14-2006, 05:49 AM   #5686
ChrisP's Avatar
Originally Posted by RCknight
I know Xray won't make one, but it's about time they start.
I can't imagine the upper deck being as low as the battery brace. Xray must be getting rid of the long bulkheads. I hope they keep the rear cf brace separate. Battery side would have to be shorter, otherwise it won't work. I hope they flip the motor and battery so the lipos will be more balanced. The electronics are much heavier.
It's going to be great to see what improvements X-ray has made on a already near perfect TC. I hope they get rid of the plastic blades and make the plastic diffs the same. Then all I need are some aluminum shock bodies with aluminum screw caps for the o-rings. I guess I'll have to wait on my tweak plate. I'm sure it will be great....lol
The Plastic blades have been around a long time and are a benefit to just about everyne who runs them.
I for one most definitely do not want to lose the blades as they save a tonne of wear and tear on the aluminum of the diffs.
I have run other cars that did not use blades and it didn't take long for the diff outdrives to get notched.
ChrisP is offline   Reply With Quote
Old 09-14-2006, 01:50 PM   #5687
RCknight's Avatar
Default The rears have never been a problem.
For me, the front cvds have been a problem. The cvd will pop out during a crash and tear up the outdrive. $60+ to replace one outdrive is nuts. Either the cvd need to be deeper in the outdrive or they need a retaining collar to keep them in place. I hope to see these new outdrive people have been talking about. Now, I know those Pro drivers never have a problem, but I'm talking about club level.
RCknight is offline   Reply With Quote
Old 09-14-2006, 01:53 PM   #5688
RCknight's Avatar
Default Can anyone PM me a quick drawing of the new car?
I would like to sell my T-2 before it's revealed to the masses. Thanks and I'll send out the guy a free servo. lol
Old 09-14-2006, 02:16 PM   #5689
Have you guys seen that? Juraj Hudy's article about Xray's recent stuff:
http://www.teamxray.com/teamxray/new...cene%20Stories
This sentence got my attention:
"Part of the new technologies is the most modern color-coating and hard-coating fully-automatic robotic line which has been exclusively designed and custom-made for us this new coating line is the most modern and advanced in Middle and Eastern Europe."
It means that soon we gonna have xray alu parts in all kinds of colors
cvt01 is offline   Reply With Quote
Old 09-14-2006, 04:20 PM   #5690
RCknight's Avatar
Default I like the idea of high quality aluminum vers.
lower qaulity aluminumbeing coated. I like the polished look anyway. With all the changes that means there are going to be some hicups. I hope they can handle it.
Old 09-14-2006, 11:23 PM   #5691
Originally Posted by berger
Ran some carpet with foams last week, car was awesome, but has a very small amount of push when cornering when using neutral power which i could do to dial out and was wanting to rotate a little too much in the really tight corners...
Was thinking i could add a little rear toe to cure that, but wasnt sure about the first. Ive got the small black shim and the 1 degree in blocks at the moment, so thats 1.5 or 2.0 degrees in off the top of my head?
Black shim is 0.75, this means you have 1+1= 2 degree toe-in
XRAY, HUDY, ORCA, KO Propo, Protoform, P1 Brand, A-Paint, RC-Trim, Xenon Racing, Matrix Racing Tires, ORCAN, DirtChamp Design
Hagberg is offline   Reply With Quote
Old 09-18-2006, 09:18 AM   #5692
jo90's Avatar
Pictures ?
Sponsored by SerpentUK, ModelTech & MTroniks
S400 / MTroniks IP6 / Team Brood / KO Propo = Loads of fun
jo90 is offline   Reply With Quote
Old 09-19-2006, 02:24 PM   #5693
Default rubber tires on carpet
Anybody use a tight chassis with rubber tires on carpet? I started with a bmi carpet chassis then went to the stock and set it with lots of flex. The bmi felt a lot better.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
porschejim911 is offline   Reply With Quote
Old 09-19-2006, 02:34 PM   #5694
hpipro321's Avatar
i race on carpet and i use all the screws put in. its best for a tight carpet track, i also lay the shocks in to the last hole
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 09-19-2006, 02:41 PM   #5695
Are you using the posts too?
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
Old 09-19-2006, 06:51 PM   #5696
James's Avatar
i run a medium chassis/top deck flex, CS-22 rubber tyres, carpet.. rather soft springs too.. making the car stiffer just makes it too unsettled and 'drifty', having said that, I use a one-way on carpet
http://www.teamadrenaline.net/ - RC Race Results, News, and gossip in Australia!
http://www.nolimitarcade.com/ - the best web flash games
http://www.fireflyhelicopter.com/ - R/C heli vids 'n more
James is offline   Reply With Quote
Old 09-20-2006, 07:07 AM   #5697
Lonestar's Avatar
Default Tam shocks?
Hey guys, has one of you fitted Tamiya fluorine shocks to his/her T2 (or T1 for that matter) - is it a direct fit, or do you need to invest in additional caps/ballcups? Dimensions ok? anything more to consider? Thanks!
Cheers,
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 09-20-2006, 07:46 AM   #5698
Patriiick's Avatar
it s a direct fit on a T2 (same length +/- 1mm)
on a FK05, you need to adapt the length shock end caps as the stock ones are too short..
But they work great.. you should email a friend in Asia on his gmail email so he can bring back some for you...
You need 3 hole pistons as standard (kit are 2) but for some extra swiss chocolate, he may help also...
Patriiick is offline   Reply With Quote
Old 09-21-2006, 01:35 AM   #5699
Lonestar's Avatar
you're everywhere, aren't you? Was wondering if you ever performed any work during your working hours
Ok mate - thanks for the feedback! What are the bottom end like, just normal open ballcups with the same diameter as the rest of tam cars (ie the blue alum balls on the TRF versions)? I'll try not to ask my buddy to bring too much stuff back as I don't want to put an INSANE amount of stress on him
Thanks everyone,
Paul
Old 09-21-2006, 05:57 AM   #5700
Send a message via AIM to canto54
Cheers,
Paul
I'm using these shocks on mine. Direct fit as said Patriiick but be carefull of the lenght because with some shoch position on the tower, they can be a bit short so I had to unscrew a little the ballcup
Robitronic Avid V2
Robitronic - Graupner - GM racing
JP Products
www.mrclongwy.fr
www.petitrc.com
canto54 is offline   Reply With Quote
