Old 09-07-2006, 07:26 PM   #5626
oracle's Avatar
Default Problem with T2 Graphite Battery Strap w/ Alu Stands (Set)
Hi, i've just bought the graphite battery strap and i found that when i try to tighthen the screws to lock in the battery, the graphite plate is about 1-2mm longer and it doesn't fit in the aluminium stands. Have i installed it wrongly? There are no instructions given and i mount it on the chassis plate near the battery. Need help. Thanks.
oracle is offline   Reply With Quote
Old 09-07-2006, 09:11 PM   #5627
cornerspeed's Avatar
The end of the strap with the thumb screw is slotted. Look at it closly. You will see what I'm talking about. It usually is stuck. If you pull on it, it should loosen up and be the correct length.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 09-07-2006, 09:27 PM   #5628
oracle's Avatar
Hi cornerspeed,
Thanks for the reply. Are you refering to this part in the picture below?
So if i pull this up, the screws will loosen up and will fit?
Old 09-07-2006, 10:56 PM   #5629
Yea, that's it. Actually the CF is slotted(hole is elongated front to rear)so no, don't pull up. Pull/Slide forward or back to free it up.
Donny Vinkemulder
TLR Driver
Old 09-07-2006, 11:34 PM   #5630
oracle's Avatar
Cornerspeed, thanks. I got it fixed now. Thank you so much
Old 09-08-2006, 12:27 AM   #5631
Cool, glad you got it fixed and I was able to help out.
Donny Vinkemulder
TLR Driver
Old 09-08-2006, 07:21 AM   #5632
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
I was just curious as to how many guys are running sway bars on their T2. I race on carpet and do not run any and the car seems alright.
I was thinking about trying them out. Is there a big diffrence with the sway bars on the car?
HRCRACER123 is offline   Reply With Quote
Old 09-08-2006, 01:03 PM   #5633
I'm not much of a carpet racer, but you may want to indicate if you are running foam or rubber tires.
Donny Vinkemulder
TLR Driver
Old 09-08-2006, 01:08 PM   #5634
oops..I forgot. It would be for foam tires.
Old 09-08-2006, 02:09 PM   #5635
Harold,
Give me a call. I ran my BMI/T2 last Sunday[email protected] Tryed plenty of things and learned a bit of what the car likes and doesn't like.
Jamie Corrado is offline   Reply With Quote
Old 09-08-2006, 02:58 PM   #5636
Originally Posted by Jamie Corrado
Harold,
Give me a call. I ran my BMI/T2 last [email protected] Tryed plenty of things and learned a bit of what the car likes and doesn't like.
Thanks Jamie. I will give you a call.
Old 09-09-2006, 10:00 AM   #5637
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
What are the common parts that break/need replacement on the T2?
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 09-09-2006, 10:43 AM   #5638
hpipro321's Avatar
nothing really if you know how to drive.. i extra stearing nuckle would be good to consider
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 09-09-2006, 06:05 PM   #5639
Anthony.L's Avatar
Trader Rating: 36 (100%+)
Front c-hub, steering knuckle, and rear upright.
Anthony.L is offline   Reply With Quote
Old 09-09-2006, 06:07 PM   #5640
Anthony.L's Avatar
