Old 08-22-2006, 09:17 PM   #5491
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
No it wont matter. All 4 holes in the adjustable pistons are the same size. The pistons will only rotate 3 clicks each way. One way is 1 hole open the other way is 4 holes open. That make sense?
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 08-22-2006, 09:19 PM   #5492
Trader Rating: 22 (100%+)
Send a message via AIM to AChupp2
Yep. Thanks.
Fantom Racing Team Manager
AChupp2 is offline   Reply With Quote
Old 08-22-2006, 09:36 PM   #5493
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Oracle- not sure about the first problem- that's gonna be something you have to figure out on the setup station... but the binding shocks I can help with; when you installed the 5.8mm balls in the top of the shock cap, you must be sure you are putting them into the correct side. If you look, one side is shiny and one side isn't. Inserting the ball from one side makes the ball sit deeper in the plastic and therefore locks the shock cap into a bind when you tighten the screw. You'll have to look at your instructions to see which side is correct cause I can't ever remember myself.
BigDogRacing is offline   Reply With Quote
Old 08-22-2006, 10:51 PM   #5494
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
The shiny side is the side that you see the hex head. I just build my kit today so I am sure.....
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 08-23-2006, 01:17 AM   #5495
oracle's Avatar
I'll go check it out tonight. Can i remove the 5.8mm pivot balls from the shocks? Will it caused any damages to my shocks? Thanks
oracle is offline   Reply With Quote
Old 08-23-2006, 04:32 AM   #5496
Got Xray?'s Avatar
Send a message via MSN to Got Xray?
Guys im moving up to mod (from stock) but have NO idea of gear ratio....i will be running and xray t2 with 84 spur(48p) orion v2 tx2 on standard sorex 28s and matched 4200s
What pinion should i use?
Thanks,
Nick
!xray!
Got Xray? is offline   Reply With Quote
Old 08-23-2006, 09:03 AM   #5497
Originally Posted by oracle
Well if you have a press where you can punch out the ball while supporting the outside of it, you might not do any harm to them, if you try with pliers and other crude tools...Yes you probably will. Best to buy new ends/caps and balls.
Hope that helps,
-Shookie <><
Old 08-23-2006, 11:26 AM   #5498
oracle's Avatar
Hope that helps,
-Shookie <><
Hi Mr Shookie. Thanks for the idea. Got the problem fixed now. Found some new problems too. Anyway the car still making a lot of noise when i go full throttle. Check the gear mesh, looks ok. Tried to roll the chassis without the motor attached, seems ok, nothing is binding. Will have to troubleshoot further.
Old 08-23-2006, 12:01 PM   #5499
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
I'm considering a return to XRay this fall. I was thinking of maybe getting the T2R and replacing the chassis with a BMI setup as I will be running only on carpet in stock and 19t. Anyone see any problems with this idea?
The composite outdrives don't bother me. I've run them on my TC3's and 4's for a while and never had a problem (though I know others who have).
Also, any ETA on the T2R's release?
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 08-23-2006, 02:04 PM   #5500
Xray released the T2r on August 15th. Its not availible in the states yet.
oracle, Have you rebuilt your motor lately? Are your diffs tight?
slowandsteady is offline   Reply With Quote
Old 08-23-2006, 02:41 PM   #5501
JCB
JCB's Avatar
What are the differences with the T2R and the T2.. I just picked up a T2 recently and really don't want to have to buy a new car.
thanks in advance...
JCB is offline   Reply With Quote
Old 08-23-2006, 03:00 PM   #5502
It is a "raycer" kit. The T2 is still a better car. This is essentially a less expensive T2 at the expense of a carbon fiber chassis and other parts that make the T2 more expensive. For more go to www.teamxray.com
Old 08-23-2006, 03:36 PM   #5503
RCknight's Avatar
Default I would get the cf T2.
Blake
If you want to run carpet then just get a CRC upper deck. Otherwise it's nice to have the flex option with the stock upper deck if you decide to do carpet/rubber tires. Just my opinion.
RCknight is offline   Reply With Quote
Old 08-23-2006, 03:49 PM   #5504
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
I haven't had any problems so far with box stock kit... minus some spring changes of course.. If you really tighten the top deck and bulkhead screws, there is no problem... atleast for me... I took a big hit in warmups before a race, checked the car after the race and its flat as could be...
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 08-23-2006, 03:53 PM   #5505
Default Need Help/Parts
Where can I find the duraluminum diff halves. I only can find the hole diff and every other part for it . Are they sold seperately
TRESFR is offline   Reply With Quote
