Old 07-22-2006, 09:34 AM   #5266
Rick Worth's Avatar
Hi Chuck. How's it going? Long time no see. R.W.
Rick Worth is offline   Reply With Quote
Old 07-22-2006, 10:53 AM   #5267
cornerspeed's Avatar
I got my IRP Plate Thursday. Work of Art. Literally.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 07-22-2006, 11:47 AM   #5268
Hey Rick,
Are you coming to the champs this year? I thought I saw you were going to vegas. I thought about that trip, but something came up. Maybe next year. Hope to see you in cleveland, should be a good time.
chuck
mackin is offline   Reply With Quote
Old 07-22-2006, 12:15 PM   #5269
Rick Worth's Avatar
I'm planning on going to Vegas again this year instead of Cleveland. I'll be back to Cleveland sometime. See ya.
Old 07-22-2006, 01:27 PM   #5270
Originally Posted by Rick Worth
Got my plate from Art at IRP yesterday. Stuck my new T2 in it & wow was it not flat! I had to enlarge the holes in the top plate to flatten it out. On a flat surface it would actually rock from side to side. Loosen the screws & it would flatten out. You could feel the 4 screws in the plate bind when I tried to tighten them down until I enlarged the top plate holes. Tried my first T2 & it was fine. I may have never known this without this product. Art also says that a lot of people just put their car in the plate right after your run & it helps cool the whole car down. Definately will be in my pit box from now on. Thanks Art. R.W.
http://www.irpsite.com/
Hey Rick-
How much to rent it once in a while from ya??
I might be going to IRP next sat for some practice.
visit Hurricane Motorsports: www.teamhurricane.net | RCAmerica www.RCAmerica.com | HUDY | JACO
bigdog xxx-s is offline   Reply With Quote
Old 07-22-2006, 01:29 PM   #5271
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
you gonna be racing too ?
we are racing on satuday nights now
wallstreet is offline   Reply With Quote
Old 07-22-2006, 03:00 PM   #5272
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Hey Rick, you might want to pull the bulkheads off that car and check them really good to be sure they are flat. It sounds like they might be bent just a touch. Make sure to check both sides of each one too, I know that sounds weird, but we ran into it one time. Seems only part of the center of the bulkhead was bent, so it looked perfectly flat on one side, but rocked on the other...
Later...
BigDogRacing is offline   Reply With Quote
Old 07-22-2006, 03:02 PM   #5273
protc3's Avatar
what up lutz,how you been brutha.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-22-2006, 04:19 PM   #5274
YO!!! Wassup Jason!!! Looks like you're doin a great job!! Keep it up.
You got my cell number- call me anytime.
Old 07-22-2006, 05:02 PM   #5275
I plan on it, along with Hunter.
Need to get the little man a little rubber practice before the first Hurricane race, he's saved up his money and has the entry for Novak. So gonna turn him loose.
I hope Shane wife is ok. Only met him once, seems like a nice guy.
Old 07-22-2006, 05:02 PM   #5276
protc3's Avatar
shoot your cell to me in a PM,i lose everything. you doing the birds this year again? you should come down august 5th.mikes throwing a carpet race at minreg.should be fun.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-22-2006, 07:29 PM   #5277
Send a message via AIM to Mongo Send a message via Yahoo to Mongo
Wierd problem...
I put a Futaba 9550 in my t2 this week. Today I was hot laping and the car was wicked darty and wouldn't trim right. When I wiggled the wheels there was a ton of slop. When I looked real close I noticed the servo arm moving but not the servo it self. The servo rocks back and fourth on the metal gear pretty bad. I have the "F" servo arm on there and man is it sloppy. Anyone else have this? I was thinking of wrapping white teflon tape on the gear to make the fit snug.
Any thoughts?
Mongo is offline   Reply With Quote
Old 07-22-2006, 07:57 PM   #5278
Chris Adams's Avatar
I have been using the futaba 9550 servo in my t2 since the t2 came out and have never had problems with it centering... Check the screw to see if it is hitting the topdeck and catching causing it to not center very easily.
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs, Ulti Tires America
Texas EOS 2018!
Chris Adams is online now   Reply With Quote
Old 07-22-2006, 08:17 PM   #5279
Ennjay's Avatar
I had issues with the xray servo horn. The splines are a bit shallow and stripped super easy on me. I couldn't figure out why my car wasn't centering, but it turns out the servo horn was shifting on the servo. I just used an associated horn with deeper splines, flipped the bolt and stering linkage to the other side and all has been good. Not sure if this is your problem, but I thought it might help.
Ennjay is offline   Reply With Quote
Old 07-22-2006, 08:19 PM   #5280
I have had mine strip out also... when it did my servo was off by over 40 clicks on my transmitter so that was fairly obvious that it stripped.
Texas EOS 2018!
