Old 07-15-2006, 10:41 PM   #5206
lbckevin's Avatar
Trader Rating: 91 (99%+)
I have mounted mine that way going back to the fk05 days...no problems with the transponder
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 07-15-2006, 11:41 PM   #5207
cornerspeed's Avatar
I've had problems no matter where I mounted the PT. Glitching that is. So, obviously its not the PT's problem. What kind of problems are you reffering to? Lap counting?
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 07-15-2006, 11:42 PM   #5208
Recieved my new BMI carpet and asphalt chassis sets yesturday. Works of art. Now waiting for the IRP Tweak Plate.
Donny Vinkemulder
TLR Driver
Old 07-16-2006, 12:10 AM   #5209
RDR
RDR's Avatar
No I was just wondering cornerspeed, Im still a noob and was reading my transponder manual, which says not to mount over cf.
RDR is offline   Reply With Quote
Old 07-16-2006, 12:20 AM   #5210
XrayFK's Avatar
Just curious, what's a good size for a 64p spur gear to fit on the T2? Thanks
XrayFK is offline   Reply With Quote
Old 07-16-2006, 12:30 AM   #5211
Registered User
I like 116T spurs. . but others have been using 114T I've seen.
Desolas is offline   Reply With Quote
Old 07-16-2006, 12:55 AM   #5212
Jochim_18's Avatar
The biggest spur fit on my T2 is 112 spur from kimbrough. What kind of spur are you guys using other than Xray?
Old 07-16-2006, 06:39 AM   #5213
Rick Worth's Avatar
RW spurs are one of the best. They fit fine with button head screws. I run from 112-120 tooth. The 120 does stick out a hair but works fine on carpet. You can get them here: http://www.pdubracing.com/rw_gears.htm
Rick Worth is offline   Reply With Quote
Old 07-16-2006, 07:22 AM   #5214
dawgmeat's Avatar
I don't think you need the tweek plate with the BMI chassis
dawgmeat is offline   Reply With Quote
Old 07-16-2006, 07:27 AM   #5215
I've got a Kimbrough 116 in mine, no fit problems
Team BSR
Team Power Push
Protoform Race Bodies
KSKT Racing - #1 in SK Racing Chassis
Darkside Motorsports - "WE ARE WHAT'S NEXT." - www.darksidems.com
THE DARKSIDE is offline   Reply With Quote
Old 07-16-2006, 08:22 AM   #5216
buzz06's Avatar
Send a message via MSN to buzz06
totally agree, thats what i use RW
buzz06 is offline   Reply With Quote
Old 07-16-2006, 10:01 AM   #5217
PitCrew's Avatar
Originally Posted by RDR
I see his transponder is mounted veritcal on his steering servo do they work fine that way, opposed to horizontal. Also does Carbon Fibre effect the the transponders signal strenght that much that you couldn't mount it on top of the servo?
Doug
I have mine mounted vertical. I have never had a problem.
PitCrew is offline   Reply With Quote
Old 07-16-2006, 11:10 AM   #5218
hpipro321's Avatar
agree that is how i mount mine and it dosent affect any signal
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 07-16-2006, 01:49 PM   #5219
same here
cvt01 is offline   Reply With Quote
Old 07-16-2006, 05:09 PM   #5220
Trader Rating: 19 (100%+)
114 spurs are easy to calculate rollout for rubber tire racing. The rollout numbers are the same as the pinion gears when worked out (ie: 33 tooth = 33.1mm rollout with 62mm rubbers). Good for lazy folks such as myself.
***Proudly supporting The Fist: "Hope everyone improve their lap time. Don't be stubborn."***
R.I.P. Tommy Kraimer, 28 time UK Champion, 4 time JMRCA champion, and engineering mastermind behind the TKX-10. The world will never be the same.
Zaner24 is offline   Reply With Quote
