Old 07-04-2006, 11:05 AM   #5116
ahsikes's Avatar
Trader Rating: 17 (100%+)
We just practiced on Sunday.
Saturday, Donny and I both got down to the 8.0's and he had the race won, got hung up, I passed him, he passed me back with a little rubbing which sent him into a pipe and he broke. I won by default.
Sunday's practice session finally broke the 8s lap. We are now changing the layout to use the rest of the track. It will be onroad only and "maybe" once a month let the oval drivers run on it.
ahsikes is offline   Reply With Quote
Old 07-04-2006, 11:39 AM   #5117
killingtime's Avatar
Originally Posted by ahsikes
Next, I ordered the chassis weight set. I did get the middle and rear sets, still waiting on the fronts. Why are some not threaded? Is this in error? Can someone shed some light on this? Thanks. Thanks for any help on this.
The weights that are not threaded are intended to have the screw pass through them. Use the threaded weight on top of the unthreaded weight to "sandwich" it in place.
As for the ackerman location, per the Xray FAQ:
"Unless otherwise noted in the setup sheet you are viewing, please use the inner ackerman position to indicate the location of the servo saver (which is opposite of the composite bearing holder tabs).
Therefore, the forward "dot" in the setup sheets refers to the servo saver being positioned forward and vice versa.
NOTE: The original T2 Setup Book has these positions reversed. Update will be posted in the near future."
Hope this helps.
Mike Webb
rD Squared-MW Designs-C and R racing
Final Thoughts RC club R.I.P.
killingtime is offline   Reply With Quote
Old 07-04-2006, 11:41 AM   #5118
X2
X2's Avatar
Default New T2R
http://www.rcinfos.com/2006/2006_07_04_xray_t2r.php
Interesting new release for the budget minded.
Wonder what the specs will be like other than the tub chassis.
X2 is offline   Reply With Quote
Old 07-04-2006, 11:46 AM   #5119
X2
X2's Avatar
Looks like theres already a thread
http://www.rctech.net/forum/showthre...29#post2479229
Old 07-04-2006, 12:11 PM   #5120
ahsikes's Avatar
thanks mike.
I also posted on the xray forum. got same response.
my only concern (keep in mind my balancing tool and front weights are not here yet so I cant try this out)
If I needed to put for example 5g weight on the car, all of my 5g are not threaded. I guess I could always put 10 on both sides and add the 5 to the unbalanced side?
and for my middle weights the 20g is the only one threaded leaving the two 10g unthreaded. What if I needed 10g?
if all the kits come this way, then great, I was just concerned that maybe one of my weights came unthreaded when it should have been threaded.
Old 07-04-2006, 12:33 PM   #5121
polesitter61's Avatar
My weights are also the same way, good old servo tape for the 5 gram weights
Slickzero R/C products, check them out, very cheap shipping!!!
www.slickzero.com
polesitter61 is offline   Reply With Quote
Old 07-04-2006, 01:18 PM   #5122
Nexus Racing's Avatar
Originally Posted by Doug Gaut
Nexus, thanks for the tips on the blades. Using a heat gun worked flawlessly.
No problem. We've been getting a LOT more life out of the blades since we started using this tip!
Originally Posted by cornerspeed
I just got a small butane torch. Will try that for heating up the blades. It can localize the heat to a finer point, and its small to fit in a pit box with me to the track. I will see how it works and let everyone know.
A torch gets the blade hot much quicker. You will have to be careful not to overheat...but it is definitely more convenient to bring a small pencil torch to the track!
I also have a heat gun that has a smaller-than-normal opening on the top that is very useful for this.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 07-05-2006, 11:00 AM   #5123
X2
X2's Avatar
The stuff ive used for years to flush out bearings seems to react with the rubber sheilds on the T2, gonna try some different stuff.
Anybody else experienced this?
Old 07-05-2006, 01:36 PM   #5124
hpipro321's Avatar
iv flushed my bearings but just used good old motor spray and waited for it to dry completely, the shields dont get worn
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 07-05-2006, 07:29 PM   #5125
dawgmeat's Avatar
Does anybody use the adjustable piston??
dawgmeat is offline   Reply With Quote
Old 07-05-2006, 07:56 PM   #5126
I use the adjustable pistons, I did'nt at first, but they seem to work just fine
www.slickzero.com
Old 07-05-2006, 07:57 PM   #5127
hpipro321's Avatar
i heard if you take a hard hit they can move... and that could get bad fast
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
Old 07-05-2006, 08:07 PM   #5128
scottwk1's Avatar
I may be wrong, but I don't see how they could move.. not with the way you have to turn the shock shaft to change them and how it is fastened around the shaft itself.. But who knows with a hard enough hit. I know I have banged some boards good and haven't had them move yet.
scottwk1 is offline   Reply With Quote
Old 07-05-2006, 09:01 PM   #5129
The shock shafts have to be fully extended and even then there is a a notch that you must get the piston into so it locks before you can change the valving. If they are on the car, and you have any amount of downstop in the car, the shock will never fully extend. So I don't see how it could happen, but anything is possible.
www.slickzero.com
Old 07-05-2006, 11:01 PM   #5130
jammin jim's Avatar
Default 64 pich spurs and pinions.
Hi Guys, anyone out there run 64 pitch??? There must be. What brand spurs work? For those experienced with 64 pitch on this car, what would be a good range of spurs and pinions to have on hand??
Thanks for the advice.
jammin jim is offline   Reply With Quote
