Old 06-15-2006, 07:11 PM   #4921
cornerspeed's Avatar
Yea, it needs more contact area for better wear. But maybe they think it would cause binding if they did that.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 06-15-2006, 07:43 PM   #4922
killingtime's Avatar
Originally Posted by protc3
i have the bodies ready,i am finishing the outdrives and then i send them out for hardening.it shouldnt take much longer.
Keep us posted on your progress!!
Mike Webb
rD Squared-MW Designs-C and R racing
Final Thoughts RC club R.I.P.
killingtime is offline   Reply With Quote
Old 06-15-2006, 07:49 PM   #4923
rayhuang's Avatar
I havent had rear pins wear prematurely if that helps and I ran some mod and 19t before (2004) and recently. Actually, recently probably 20, 30 packs of mod and rear pins are fine.
Old 06-15-2006, 09:25 PM   #4924
Rick Worth's Avatar
I ran Shumacher blades on one of my TC3s for 5 years with no wear. Front or rear.
Rick Worth is offline   Reply With Quote
Old 06-16-2006, 09:19 AM   #4925
I have used some aftermarket diff halves that were wider on my TC3 and didn't have any problems with binding. They worked pretty well actually, but I think XRAY could solve this problem by simpy using a different material. Something that a little more durable
DOTMAN is offline   Reply With Quote
Old 06-16-2006, 11:36 AM   #4926
ottoman's Avatar
R/C Tech Charter Subscriber
After reading the last few posts I went and looked at both of my T2's... one is my 19t foam car and the other my rubber tire car. Both have been run hard and neither has had a blade changed yet. I can see no blade wear on either car.... I remember changing a blade on my 05 once.... but I think it was due to a bad crash
ottoman is offline   Reply With Quote
Old 06-16-2006, 02:28 PM   #4927
Trader Rating: 198 (100%+)
Yep. its the rears that wore out like that. Wierd I would think. I just wanted some feedback from those that have been running it for a while now. I go through front blades in about 2 runs with a spool. Which is normal for me.
I talked to Butter the other day and he is running mod changing blades about every 2 runs he said.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 06-16-2006, 02:38 PM   #4928
Dude...I don't know what you're doing cause every XRAY guy I know has a bucket of extra blades in their pit bag cause they go through them so fast.
Old 06-16-2006, 05:55 PM   #4929
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Hi Guy,
i was new to T2 i do not know whether this is normal. when i place my top deck in the chassis i found out that after i put everything in and going to screw it the deck was slanted a bit to right side. then after i screw it i found out the top of the steering bellcrank was slanted to the left side? is that normal? thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 06-16-2006, 06:01 PM   #4930
scottwk1's Avatar
You might try flipping the top deck over. The hole on top is off centered that the bellcrank fits into.
scottwk1 is offline   Reply With Quote
Old 06-16-2006, 06:18 PM   #4931
protc3's Avatar
blades wear out in stock and 19 turn also.that is there purpose.to absorb the impact and save the outdrives.this is not just on the t2 but all cars that use them.it is even harder on them when using a oneway or a spool.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 06-16-2006, 06:46 PM   #4932
Nexus Racing's Avatar
I was having a lot of problems out of my rear blades recently (running mod). They were wearing the inside of the blades to the pin in only 2 runs because the blades were not grabbing the "ball" of the dogbone tightly enough...in other words, there was a lot of up-and-down slop.
To prevent this, I started doing this modification:
Put the blade on the dogbone and lightly squeeze it with a pair of pliars so that it "grabs" the ball of the dogbone. Then, just heat up the top part of the blade (the "apex") with a heat gun, and let it cool while you are still squeezing it. It will then have a lot better contact area with the outdrive and wear a lot better. After doing this mod, I have run the car about 10 runs without having to change the blades .
I am going to add this tip to our XRAY T2 Tips & Tricks page pretty soon, but since the subject came up, I went ahead and explained it here.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 06-16-2006, 06:50 PM   #4933
That's a good tip Nexus. Did that help on the front too?
Old 06-16-2006, 07:09 PM   #4934
Guo Chean's Avatar
Arun you are the man.
Old 06-16-2006, 07:16 PM   #4935
ottoman's Avatar
I dont know... maybe its a asphalt thing... I race carpet
