Old 06-12-2006, 07:38 PM   #4891
Thanks, Don...unfortunately they're not really ballends. The end fits over a hollow sleeve that's round on the outside. The end snaps onto the round part. You put a screw through the sleeve to screw it to the Chub. Problem is there's so much play between the sleeve and end that the wheel probably has as much as 4 degrees of play if looking from a camber perspective. My car lacks a little turn in too. Makes my wonder how that's affecting front grip. Puts more guess work into setting camber.
DOTMAN is offline   Reply With Quote
Old 06-12-2006, 08:49 PM   #4892
Just thought I would post a few pics of my Lipo powered T2. The modifications to get the Lipo to fit turned out really nice. I took the rear bulkhead into work and had a machinist remove material up to the tangent of the hump. Put spacers under the battery strap. Modified all four plastic pieces at the corners of the battery, note the two outboard pieces I had to take the sides down as well to slip the battery in.
Davenport is offline   Reply With Quote
Old 06-12-2006, 09:23 PM   #4893
hpipro321's Avatar
nice work on gettin that thing to fit in
looks lyk a hard one
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 06-13-2006, 07:00 AM   #4894
This play makes it very difficult to get a precise amount of camber in the tires.
Team BSR
Team Power Push
Protoform Race Bodies
KSKT Racing - #1 in SK Racing Chassis
Darkside Motorsports - "WE ARE WHAT'S NEXT." - www.darksidems.com
THE DARKSIDE is offline   Reply With Quote
Old 06-13-2006, 07:04 AM   #4895
Mark G's Avatar
Send a message via AIM to Mark G
Nice work.
Mark G is offline   Reply With Quote
Old 06-13-2006, 08:36 AM   #4896
Michal101's Avatar
Originally Posted by cvt01
I think I read in this thread that the roll center area break issue has been addressed on the new series of shock towers (and cars of course) - I may be wrong
CVT01,
Nope you are 100 % correct. Xray came out with newer thicker shock towers a few months back because of this issue, but they kept the same stock numbers.
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Michal101 is offline   Reply With Quote
Old 06-13-2006, 08:54 AM   #4897
Send a message via AIM to Mongo Send a message via Yahoo to Mongo
Can someone tell me the difference in thickness? SO I can measure mine and see which I have.
Mongo is offline   Reply With Quote
Old 06-13-2006, 09:55 AM   #4898
teamgp's Avatar
FYI,
The small aluminum braces previously used on the FK05 adjustable top deck will also work well to stiffen the T2 top deck. Two of them should be mounted in the middle and rear hole pairs along the center cut of the top brace. (see image)
The braces will be made available separately on an updated price list in the near future (no specified date at this time).
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 06-13-2006, 02:12 PM   #4899
Nexus Racing's Avatar
They have the same thickness as the old towers, but with more material around the roll center area for more durability.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 06-13-2006, 05:56 PM   #4900
Suspended
Trader Rating: 28 (100%+)
Anyone have Travis Schreven's winning setup for Onroad Nats this last weekend? Or Esposito's?
TANKS!
racenut123 is offline   Reply With Quote
Old 06-13-2006, 06:35 PM   #4901
I'm still trying to find his setup from the Reedy Race
Old 06-13-2006, 06:50 PM   #4902
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
I have his setup from the reedy, and i have everything from the nats but Droop. When I asked him for the droop he said it was eyeballing it.
Reedy was:
2 Caster
2 Camber all around
5 Front droop
4 Rear
0 Front toe
2.5 rear toe
White Springs front
Yellow back
Middle Roll Center
Nats Was:
4 caster
2 camber all around
Blue/green color spring all around
Front and Rear Sway bars: Gold
0 Front toe
2.5 rear toe
Middle Roll Center
I used his droop from the reedy 5/4
This is close. I think, not sure, he might of had a 1.5 shim in the front and 3.0shim in the back of the front arm. If that makes sense.
Nick
JohnMatrix is offline   Reply With Quote
Old 06-13-2006, 06:59 PM   #4903
Reedy was:
2 Caster
2 Camber all around
5 Front droop
4 Rear
0 Front toe
2.5 rear toe
White Springs front
Yellow back
Middle Roll Center
Nats Was:
4 caster
2 camber all around
0 Front toe
2.5 rear toe
Middle Roll Center
Nick
Thanks, Nick...but do you have the complete setup with arm spacing and shock oil, etc
Old 06-13-2006, 07:18 PM   #4904
JohnMatrix's Avatar
I think Walter C does. I'll email him tonight and see if I can get it.
Im pretty sure it's 3 holes open and xray 30 wt.
And arm spacing is the orginal from the kit set up.
But With my luck im prob totally wrong and everyone will go out and run the wrong stuff, so Ill double check as soon as I can.
Old 06-13-2006, 07:56 PM   #4905
Thanks, Nick
