Old 06-12-2006, 09:39 AM   #4876
Send a message via AIM to WhoMe
Certainly..Thanks for the advice GP.
WhoMe is offline   Reply With Quote
Old 06-12-2006, 10:46 AM   #4877
Glowster21's Avatar
Trader Rating: 116 (100%+)
Planning on messing around with a T2....What breaks on these cars? C-Hubs, Knuckles, Arms......Anything more than others?
Glowster21 is offline   Reply With Quote
Old 06-12-2006, 10:49 AM   #4878
dawgmeat's Avatar
Originally Posted by teamgp
Unfortunately I can't help you there as I work more in hand with the product support team and HQ. Questions for team drivers should be directed to them or their respective national distributor which provide the sponsorships.
In regards to the Reedy Race, I'd suggest sending an email to RC America, a PM to rmargiotta (he works for RC America), or post a message in the Ask Mike Blackstock thread. They should be able to help.
thanks budd also, do you still race at Debbies, all the fast guys seem to be running 19
dawgmeat is offline   Reply With Quote
Old 06-12-2006, 10:56 AM   #4879
dawgmeat's Avatar
steering knucles and the castor block sad to say are a package deal" you break one the other goes with", I'm running aluminum steering knuckles and rear hubs, the rear shock tower in the area of the roll-center adjustment will give out on a very bad crash but being the greatest unsigned hype that want be a problem for you
Old 06-12-2006, 12:19 PM   #4880
I think I read in this thread that the roll center area break issue has been addressed on the new series of shock towers (and cars of course) - I may be wrong
cvt01 is offline   Reply With Quote
Old 06-12-2006, 12:39 PM   #4881
Is it just me or does the T2 seem to develop a great deal of "play" in all of the ti-rod linkages? Does anybody have any suggestions to minimize this issue?
Team BSR
Team Power Push
Protoform Race Bodies
KSKT Racing - #1 in SK Racing Chassis
Darkside Motorsports - "WE ARE WHAT'S NEXT." - www.darksidems.com
THE DARKSIDE is offline   Reply With Quote
Old 06-12-2006, 01:00 PM   #4882
I commented on that a few weeks ago but didn't get a good response from anyone. Either ballends are to big or the ballstuds are too small. There's a lot of play between them
DOTMAN is offline   Reply With Quote
Old 06-12-2006, 01:01 PM   #4883
Joep's Avatar
In my opinon is this not an issue. I got it too. The play is settled to one side when you're driving.
Xray T3 for dry and Xray T2'009 for rainy weather. Sponsored by: Myself and my wife.
Joep is offline   Reply With Quote
Old 06-12-2006, 03:22 PM   #4884
stiltskin's Avatar
Trader Rating: 102 (100%+)
I just noticed the slop in my car last night. They were tight when I built the car so I'll assume that new rod ends will fix it. I still have less slop than what is typical with ball cups.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 06-12-2006, 03:24 PM   #4885
Not true with me. I have so much slop, I thought I had broken something
Old 06-12-2006, 03:29 PM   #4886
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Just put a shock o-ring behind each ball end. If you're worried that they are binding the suspension, take the shock off and you'll see that it's still just as free as it was before. I like to replace the o-rings in my shocks at least every other month or two, so unless your o-rings get torn, use the ones you take off. It's cheaper that way....
BigDogRacing is offline   Reply With Quote
Old 06-12-2006, 03:31 PM   #4887
protc3's Avatar
Originally Posted by WhoMe
So what do you think about the spool? Im running asphalt with rubber tires and Ive been looking over various setups. Most of the setups differ, but almost all all them seem to have one thing in common...the spool. Im currently running two diffs and Im having trouble with off power steering..specifically mid turn where the car will push. I have to slow down signifcantly so that the car will maintain the line...if I give it any throttle at that point it will continue to push out. So basically I lose a lot of momentum on low speed turns. I was wondering if switching to a spool will make alot of difference. Some swear by it.
a spool is the hot ticket on asphalt.you will get a ton of on power steering with it.it loses the turn in that a oneway has but you can be alot more aggressive with a spool.you just need to get your turn in through your set up.9 out of 10 times a spool is the best for asphalt racing.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 06-12-2006, 04:14 PM   #4888
Got Xray?'s Avatar
Send a message via MSN to Got Xray?
Default Tamale
Hey guys,
I bought my T2 about a month ago and it came with team tamale alu front c-hubs(not installed),but no sleeves to make them fit does anyone know where i can get them?
!xray!
Got Xray? is offline   Reply With Quote
Old 06-12-2006, 04:38 PM   #4889
cornerspeed's Avatar
When you snap on the ball cups, use plastic parts bags over the ball stud, then pop the the ball cup on. Remove excess bag. All the slop should be gone.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 06-12-2006, 07:29 PM   #4890
hpipro321's Avatar
or you coulb buy those tamiya and associated foam pieces and just slide them over the studs
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
