Old 05-30-2006, 10:56 AM   #4786
buzz06's Avatar
Send a message via MSN to buzz06
I know 84 and 87 do
buzz06 is offline   Reply With Quote
Old 05-30-2006, 12:09 PM   #4787
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
speaking of spurs... which aftermarket spurs are you guys running w/o modification?
☆ Joe Tran ☆
tr1kstanc3 is offline   Reply With Quote
Old 05-30-2006, 12:24 PM   #4788
pucho's Avatar
Send a message via AIM to pucho
I'm using the PRS spurs
pucho is offline   Reply With Quote
Old 05-30-2006, 12:45 PM   #4789
Hi
I have a 90 spur in my T2 don't think you could go any bigger as this is a tight fit through the bottom of the chassis, I think if you go bigger you will need to go 64dp
Mike
casper7 is offline   Reply With Quote
Old 05-30-2006, 01:00 PM   #4790
Trader Rating: 37 (100%+)
Originally Posted by casper7
Hi
Mike
Mike are you saying it's a tight fit meaning it sticks out the bottom? Or is it close to the edges of the hole opening in the lower chassis?
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 05-30-2006, 03:27 PM   #4791
Chris08527's Avatar
Trader Rating: 16 (100%+)
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 05-30-2006, 04:43 PM   #4792
buzz06's Avatar
I use RW Racing spurs
Old 06-01-2006, 11:01 AM   #4793
Sleighty's Avatar
Hi,
I might be getting myself a T2 2morrow and i wondered if you guys could make a list of important hop ups/spares etc i will need. I will be running the car on both carpet and tarmac. The car is UK spec so it comes with the multi diff.
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 06-01-2006, 11:23 AM   #4794
I can run any spur gear i want now as i have a 4 stud spur hub.
Rick Draper is offline   Reply With Quote
Old 06-01-2006, 11:25 AM   #4795
No offense Sleighty but you are at least the third guy asking for this list and we put together the list every time they asked for it. Please use the search function (that's why they keep all the posts anyway).
cvt01 is offline   Reply With Quote
Old 06-01-2006, 11:36 AM   #4796
Sleighty's Avatar
Yer ok point taken i'll see what i can get search wise, any idea how many pages back it might be approx?
A1-RC.com
Team Scream
Xray
Old 06-01-2006, 03:26 PM   #4797
dawgmeat's Avatar
Default set-up
any luck with RROC set-up?
dawgmeat is offline   Reply With Quote
Old 06-01-2006, 08:21 PM   #4798
rayhuang's Avatar
Have you guys played with track width much?
I ask because when I first built the car, I built it with 3m innner shims all around (for Jaco tires), but run Parmas so my car was ..umm... about 192mm or so. I rebuilt it with 1.5mm shims all around and was now shy of 190, but more to the point of al this, car got edgy with a high steering set-up on it (6 deg caster, low front roll) and doesnt seem t carry the corner speed it did when it was 192+mm. I am now again at 190. I added a black shim (0.75m) all around and may or may not get to test it for awhile.
I am hoping someone else test crazy has played around with this tuning aid.
Ray
Old 06-01-2006, 09:09 PM   #4799
Send a message via AIM to Mongo Send a message via Yahoo to Mongo
How do you put kick up in the rear? Offset the rear roll center med/high or low/medium.
Mongo is offline   Reply With Quote
Old 06-01-2006, 09:56 PM   #4800
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
It isn't called kickup in the rear- it's called squat. Anti squat is the pins leaned back, for example you would run mid/low or high/mid. Pro squat is the pins leaned forward- low/mid or mid/high.
The reason the rear is referred to as squat is because the changes in angle affect the car on power more than off.
BigDogRacing is offline   Reply With Quote
