Old 05-29-2006, 01:16 PM   #4771
Send a message via AIM to WhoMe
Originally Posted by pinggoy
try tamiya shocks...its so smooth...and it has aluminum body....
Do they sell these in any other color..other than blue? Im thinkin Im going to get these for my T2. Also are any modifications needed to run these shocks?
WhoMe is offline   Reply With Quote
Old 05-29-2006, 01:52 PM   #4772
buzz06's Avatar
Send a message via MSN to buzz06
I think you can get them in a silver/gray colour
buzz06 is offline   Reply With Quote
Old 05-29-2006, 01:57 PM   #4773
pucho's Avatar
Send a message via AIM to pucho
Originally Posted by PitCrew
Hey, that looks like a honda civic Tac....?
9 grand? Si?
No the SI one has SI screen printed on it It couls however be a Type R one.
pucho is offline   Reply With Quote
Old 05-29-2006, 02:01 PM   #4774
pucho's Avatar
Originally Posted by wallstreet
How are you guys spacing the front end out so that the parma rim doesnt hit the spring perch ?
Xray now has hexes with different offset there are + .75mm and -.75mm ones.
Old 05-29-2006, 02:04 PM   #4775
pucho's Avatar
Here you go.
http://www.speedtechrc.com/store/ebp...id=270&id=4544
Old 05-29-2006, 02:05 PM   #4776
berger's Avatar
R/C Tech Charter Subscriber
When using tamiya shocks, are you limited to what droop you can run, or is there a longer piston you can run, or different ballcups for the bottom which increases the length of the shock compared to the xray one.
berger is offline   Reply With Quote
Old 05-29-2006, 03:46 PM   #4777
I've run my T2 for three races now and I've noticed that there is a lot of play between the pivot balls and ball joints causing particularly my front wheels to feel real loose. I can't tell where my camber setting really is because of the excessively play. Has anyone else experienced this and if so, what did you do to fix it?
DOTMAN is offline   Reply With Quote
Old 05-29-2006, 04:00 PM   #4778
ottoman's Avatar
Mine are the same way... I just run it as it doesnt seem to bother anything
ottoman is offline   Reply With Quote
Old 05-29-2006, 07:21 PM   #4779
Default play
The small bearings are the root cause of the play... The 05 big bearings gave less play but more rotating mass...
I assume the 415 and the RDX are the same (similar size of small bearings)
cvt01 is offline   Reply With Quote
Old 05-29-2006, 09:47 PM   #4780
No it's not the bearings. It's definitely the ball joints and pivot balls
Old 05-29-2006, 09:57 PM   #4781
chicmagnet's Avatar
tnx guys!!! im planning to those pairs in our local hobby shop. but im confuse! its expensive ang i might not get any improvment on those. anyway, im running on an aspalt track with a low traction. how can get a maximum traction?? tnx!
STRAIGHT LTD.
chicmagnet is offline   Reply With Quote
Old 05-29-2006, 10:08 PM   #4782
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
change your setup.... mybe lower the shock angle slightly inward..
it depends, if the only reason your car is not handling well.not your driving skills. then mybe changing something will works...for my case it did change my car handling..big time....
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 05-30-2006, 04:47 AM   #4783
Drewdc90's Avatar
you could try softening you chassis if you haven't already.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 05-30-2006, 05:53 AM   #4784
Use the associated ends mate
c you soon
Nick Simpson is offline   Reply With Quote
Old 05-30-2006, 10:55 AM   #4785
Trader Rating: 37 (100%+)
What range of 48P spurs fit the Xray T2 without modification?
84, 87, 90, 93, 96, 99 ?
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
