NEW XRAY T2
#4756
Originally Posted by RCknight
can you come up with something? You would think Xray would want to release a mod bulkhead since a lipo will fit into a Corrally.
As it stands now there is no set shape or design for LiPo packs. If a change is made to accomodate the Orion packs it may not work with future releases from other manufacturers.
This is not an official Xray statement...merely my observations based on my experiences in design, sales and marketing.
#4757
Page 3
#4758
Originally Posted by X2
Heres a couple of pics of the T2 underbody for anybody who's interested.
The quality isnt perfect but you get the idea.
rc magic guys
#4759
Originally Posted by hpipro321
oooooooo when lipo becomes legal u gota show all of us how u did that
rc magic guys
rc magic guys
#4760
Originally Posted by rayhuang
Have you tried high rear roll with antisquat? Maybe a rear sway bar as well?
Two tracks local to me are "special" at best, but its a place to race.
I wasn't sure how a rear sway bar would work on pavement with rubber tires.
Second question... You can run different roll center front vs. back?
#4761
A swaybar won't change your dampening characteristics it will only increase the "roll Stiffness" so if you are running on a bumpy track you could use soft springs and light weight oil but use the swaybar to control the roll on the corners.
Yes you can run different roll centes front to and rear.
#4762
Thanks Pucho...
And yet another...lol Sorry guys.
My chassis is grinding the pavement through this long fast sweeper. Other then jacking my ride height up, what can I do? Would the answer above on sway bars help the car not roll as much through the sweeper? should I run both? just curious.
#4764
is there a t2 aluminum shocks??? i hate the plastic shocks!
#4765
guys,
what are the effects if i replace an aluminum rear hub and an aluminum steering blocks???
#4767
How are you guys spacing the front end out so that the parma rim doesnt hit the spring perch ?
#4768
Originally Posted by chicmagnet
guys,
9 grand? Si?
#4769
guys,
#4770
guys,
Many times switching to aluminum rear hubs will slightly stiffen your car up very similar to switching hardness of your A-arms. The plastic hubs will have a little more flex to them which could aid in traction So, having said that if you are racing on asphalt this is something you may want to try out during practice.
I hope this helps, Mike
