Old 05-16-2006, 04:47 PM   #4666
Anthony.L's Avatar
Trader Rating: 36 (100%+)
Originally Posted by Nexus
When people run a oneway and/or spool with their T2's outdoors are you pretty much using the Xray MultiDiff or is there a specific spool only and oneway only thing?
Xray in the past did make a solid spool only but I'm pretty sure it's discontinued. Now the only option is the multidiff which gives you all three possible spool/one-way options. The only disadvantage to the Multidiff when running in spool mode is the extra weight. Because of the one way bearings and larger housing, a solid spool only would be lighter. I noticed for this reason, the Xray team drivers run the solid spool and not the multidiff.
Anthony.L is offline   Reply With Quote
Old 05-16-2006, 06:39 PM   #4667
geeunit1014's Avatar
but the car is already underweight
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 05-16-2006, 06:43 PM   #4668
Send a message via Yahoo to CoryCraig
its not to save static weight, but rotating weight. Less rotating weight = faster acceleration. if you took 20grams of static weight off the car ( titanium screws, actual weights, or anything else to shave non moving weight ) you would see minimal gains on the track, but shaving 20 grams off the transmission in some way you would most definatly see on the track everytime you pull the trigger.
CoryCraig is offline   Reply With Quote
Old 05-16-2006, 06:43 PM   #4669
Greenbandit's Avatar
I just got my T2 and will be running 19T on a fairly large track. Our straight is about 150ft and the infield somewhat tight. Not being familiar with the T2 100%, I was wondering where I should start with gearing? I will be running a Komodo 19T. Thanks in advance.
Todd Daly
Greenbandit is offline   Reply With Quote
Old 05-16-2006, 07:15 PM   #4670
protc3's Avatar
a good starting point would be 1 tooth under a c2
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 05-16-2006, 09:39 PM   #4671
Thank you for the response, but unfortuneately, I have not run a c2, so still not sure where to start? Looking for a final drive ratio if possible. I heard that I should start around a 7.6, but wanted to get some more input. Thanks.
Todd Daly
Old 05-17-2006, 04:11 AM   #4672
protc3's Avatar
i ran my c2 at a 6.1
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-17-2006, 09:49 AM   #4673
Thanks protc3, I appreciate the info.
Todd Daly
Old 05-17-2006, 01:23 PM   #4674
pucho's Avatar
Send a message via AIM to pucho
Jason:
Any word on a spool for the T2 I know xray sells the Multidiff but that thing weighs a ton.
pucho is offline   Reply With Quote
Old 05-17-2006, 01:34 PM   #4675
RCknight's Avatar
Default Anyone know if Xray will come out
with a new battery side aluminum bulkhead? One that will fit a Lipo.
RCknight is offline   Reply With Quote
Old 05-17-2006, 03:59 PM   #4676
protc3's Avatar
im hoping to have a spool finished shortly.i have been insane busy at the shop and im trying to get it all cleared up so i can get back to the rc stuff full roar.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-17-2006, 04:08 PM   #4677
rayhuang's Avatar
sure-pus off the stuff that really pays the bills lol btw-would you rather be blown or injected HA!!
Hey all-I noticed on the set-up sheets that people generally run (Carpet/foams) either mid roll front to back, or if they go with slammed front roll, they always use high rear roll.
Heres the question...Is this a case of "high bite" or is something to do with running the front rc slammed?
Thanks,
Ray
Old 05-17-2006, 05:07 PM   #4678
Ray,
Front down-rear mid or up changes the "Roll Axis" which makes the car turn more. If the track has very low bite you may not be able to raise the rear as much.
Ted
Ted Flack is offline   Reply With Quote
Old 05-17-2006, 05:18 PM   #4679
teamgp's Avatar
From what I've observed running foams on carpet (medium grip club level track), the T2's chassis setup seems to allow the rear end to be very forgiving with a maximum steering setup. I'm not sure about the top drivers, but I found that running the front arms in the low roll center position and the rear arms in a high roll center position allowed the car to hold a very tight line mid corner at higher cornering speeds. This setup also helped to free up the rear end for better rotation coming out of the corners on-power. I believe this doesn't work as well at extremely high grip events though.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 05-17-2006, 07:19 PM   #4680
pucho's Avatar
Cool, I saw the one Marcos has and it's a work of art.
