Old 04-24-2006, 01:01 PM   #4456
stiltskin's Avatar
Trader Rating: 102 (100%+)
Originally Posted by macaofriend
Hi folks, quick question on the front universal bone for the T2. Are there any after market universal bones for the T2? Or everyone basically just use the original from Xray?
TIA.
If you're talking about the CVD "bone", the spring steel ones work just fine. I've never had an issue with one. Maybe the one-way/ spool crowd could offer a different opinion.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 04-24-2006, 01:44 PM   #4457
macaofriend's Avatar
Trader Rating: 19 (100%+)
Default Bone
I have the multi diff and I am talking about the "CVD" bone, except it really is a universal. Anyway, I bent one and in searching for a replacement, I see that each of these is around $20 and I was wondering if anyone has used any other brands? For example MIP or some others?
macaofriend is offline   Reply With Quote
Old 04-24-2006, 05:13 PM   #4458
Chris08527's Avatar
Trader Rating: 16 (100%+)
guys is there any pattern to tighten both the bulk heads and the top deck to elimate tweaking???
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 04-24-2006, 05:18 PM   #4459
if you just "X" the torque pattern, that works pretty well. Meaning do the left front, right rear, right front, left rear, and then repeat on the inner screws. Pretty much like a head gasket on a 1/1 car.
Art Jensen is offline   Reply With Quote
Old 04-24-2006, 05:19 PM   #4460
Chris08527's Avatar
thanks ART
YOU'VE GOT MAIL!!!
Old 04-24-2006, 06:46 PM   #4461
C_O_jones's Avatar
Do it just like a real car- always start from the center then go out.
If you start from the ousides it can put a bow in the center.
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 04-24-2006, 08:28 PM   #4462
Chris08527's Avatar
same X pattern bit start from the inside???
Old 04-24-2006, 08:44 PM   #4463
hpipro321's Avatar
it dosent matter
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 04-24-2006, 09:30 PM   #4464
steveM3's Avatar
Default The new XRAY TWEAK PLATE
I had the opportunity to demo one of the first Tweak Plates from Art Jensen (manufactured by BMI) this weekend at Superior Hobbies. Let me just tell you that this is a piece of rc luxury. It saved me a lot of time and hassle because I didnít have to use the droop blocks to square everything up. Jared Scott also used the Tweak Plate all weekend before every run to make sure the chassis was perfectly flush with the bulkheads. He will be taking it to Germany next week.
Art told me that several have ordered their tweak plate already. There are 20 plates being run tomorrow night and should be released very soon. Mike Blackstock and Ralph Burch will also be receiving one. Several notable Xray drivers came by the trailer to borrow the tweak plate including Dave Bowser and Mr. EA (Eric Anderson) himself. I guarantee they will be ordering one. Chris Tossolini, (Corally RDX) showed a lot of interest so I believe Art will be looking into making a plate for the RDX. The cool looking standoffs that hold the chassis to the plate are made from nickel plated brass and have stainless steel grip screws on top. I believe they are going to be sold separately.
Art, this are the fact I remember from the race but what other info do you have. I know it is early but how can people order the Tweak Plate and what is the final price????
NEW XRAY T2-masters2006-132.jpg   NEW XRAY T2-masters2006-141.jpg   NEW XRAY T2-masters2006-153.jpg
Steve McNichols
Serpent- Desoto Racing
steveM3 is offline   Reply With Quote
Old 04-25-2006, 12:01 AM   #4465
Default Chassis 05 needed
If anybody has a Xray FK'05 chassis that they want to sell let me know.
Thx email [email protected]
Charles is offline   Reply With Quote
Old 04-25-2006, 06:09 AM   #4466
new92's Avatar
For Art's plate, you just loosen everything then attach the 4 posts through and attach to the chassis? then tighten everything back up?
Just got my T2 last night and starting to build tonight. I may have to grab me one of these in the next few weeks too lol.
new92 is offline   Reply With Quote
Old 04-25-2006, 06:19 AM   #4467
new92's Avatar
Oh btw, when I ordered the car from RCshack I asked them how long they had hadit in due to some of the runnig updates and whatnot. They said they had just gotten it in earlier in the week. When I opened the box there was a set of foams in it. I was under the impression that the foams just came with the first runs and/or preorders.
Are they coming with all of the kits now or did I get an old kit?
Since i only race on asphault with rubber are they worth anything to sell?
Old 04-25-2006, 07:02 AM   #4468
i think 2 foamies are about $10 us? so for a set they are $20 us. this is a rough guess from what i saw on stormers. if you have no use for them sell them. foam after about 6 months or so goes of anyway and gets hard.
on another note, i have a t2 that does nothing but push on corner exit.
i have the following setup
FRONT
-kit silver springs 30wt GS oil 2 holes open
-4.5mm ride height
-droop small amount of lift, but not alot
-shock pos outside hole on arm, 2nd from bottom on tower
-lowest roll centre
-camber link lowerhole outer
-caster 2 degrees (ive tryed 6 but really doesn't do much, if anything it was worse with 6)
REAR
red springs, 30 wt gs oil 3 holes open
-5mm ride height
-shock outside on arm top hole on tower
-camber link lower hole outer
-rear arms angled forward
-stiffest swaybar
36 sorex medium b all round
no matter what i do it pushes on exit when i go on the power. if i tighten the diff it becomes hard to drive (small track) and it turns in bad
how can i get rid of exit push? as last resort o have taken out 4 screws on the top deck and the front posts to try to instigate more grip, but this seems like a pritty bodgy method if you ask me. my rear end is supper stiff yet is still feels crap on exit
TomB is offline   Reply With Quote
Old 04-25-2006, 10:30 AM   #4469
Default Xray 05 for sale 100 in for sale area
Hello, I have a Xray '05 for sale ($100) in classified section.
email- [email protected]
Old 04-25-2006, 12:43 PM   #4470
@TomB: try running a spool or one way !! and 4 degrees caster. If you need more steering, make the front trackwidth smaller by removing the spacers between the bulkheads and pinholders.
Frans H is offline   Reply With Quote
