Old 04-20-2006, 02:22 PM   #4426
EricF's Avatar
Originally Posted by new92
Ok, I think I am ordering the car tonight or tomorrow. I am thinking 1 each of front and rear arms and a few of each degree of chubs....some steering blocks....anything else to get going with it? Going to order a Pdub bumper at same time.
I have misc things like belts, diffs, etc from my 04. Just dont want to have to turn around and order something else from breakage right away. Would at least like a few weeks on it lol. The layout we are running now is pretty wide open so the potential of hitting pipes arent bothering me too bad.
Maybe front and rear shock towers. Although they have been revised in the new kits around the roll center mounts. Also extra spacers for track and toe adjustments.
E
EricF is offline   Reply With Quote
Old 04-20-2006, 02:24 PM   #4427
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Multi Diff/Spool and lots of blades. Rear Hubs. and the steel inserts for c hubs...
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 04-20-2006, 08:14 PM   #4428
Wap
hey guys do u know of any video clips of races i can down load?
Wap is offline   Reply With Quote
Old 04-20-2006, 08:28 PM   #4429
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
With the run of kits that are coming off the line now, have the problems been fixed? I am talking about the chassis tweak, and the rear toe in. I don't want to buy a car and then have to buy a bunch of stuff like top decks and new chassis plates to fix the problems with my "new" car. I haven't bought one yet, ut am thinking about one for next carpet season.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 04-20-2006, 09:07 PM   #4430
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
What steel inserts for the C-Hubs..
HRCRACER123 is offline   Reply With Quote
Old 04-20-2006, 11:13 PM   #4431
Nexus Racing's Avatar
He's talking about the steering bushings...those little bushings that fit inside the c-hub above and below the steering block.
This is probably the most frequently searched-for piece on the track after breaking (for any car manufacturer, really) .
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 04-21-2006, 05:24 AM   #4432
Send a message via AIM to R/C Anonymous
I lose those once in awhile when the C-Hub goes bye-bye. Good thing I got a couple spares.
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 04-21-2006, 05:53 AM   #4433
new92's Avatar
Ok, I am about finished with the list lol.
I can use my spool from the 04 right? And I read about a guy using the oneway too just flipped the gear to the other side of the axle and used washers to space it out. I will pick up a multi-diff eventually but will probably be next month when I get my summer paychecks. Trying to keep the initial cost down and then sell the other cars to buy more spares with once I run it a few times and check the durability lol.
so far:
Steering blocks
c-hubs and inserts (I had not even thought about these even though I did lose 1 once in the 04)
I still have about 12 blades from the 04 I am assuming they fit the new axles
So far everywhere I looked has been sold out of the shim kits but will keep looking for them
new92 is offline   Reply With Quote
Old 04-21-2006, 08:57 AM   #4434
Registered User
You should be able to, like you said it should be just like the one way installation. Just flip the gear, and shim it .5mm. I'm using a T1 one way in my car. If you have any 0.75mm shims those would probably be ideal, .5mm is just a touch off from being perfect but it works just fine.
The blades are the same.
Desolas is offline   Reply With Quote
Old 04-21-2006, 09:20 AM   #4435
It is a spool!!!! you can just flip the whole thing BUT the FK04 pulley has only 32 teeth the FK05/T2 pulley has 34. Make sure that you change your pulley to a 34 teeth one.
cvt01 is offline   Reply With Quote
Old 04-21-2006, 11:11 AM   #4436
hpipro321's Avatar
lol funny if you put the wrong spool on
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 04-21-2006, 11:36 AM   #4437
new92's Avatar
I originally bought it when I had a Raycer and used the 34 pulley on it, then when I got the FK I just bought an extra pulley so its all good
Old 04-21-2006, 12:28 PM   #4438
killingtime's Avatar
Try searching for Take Off shim kits, they're very nice If you can't find the Xray brand.
Mike Webb
rD Squared-MW Designs-C and R racing
Final Thoughts RC club R.I.P.
killingtime is offline   Reply With Quote
Old 04-21-2006, 01:07 PM   #4439
hpipro321's Avatar
the tamiya aluminum ones will also work....there the blue ones
you can also use the hpi ones ( a little more expensive but is a last resort)
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
Old 04-21-2006, 01:26 PM   #4440
Anthony.L's Avatar
Trader Rating: 36 (100%+)
I use the Tamiya shim kit. They are readily available, cheaper, and you get twice as many shims.
Anthony.L is offline   Reply With Quote
