NEW XRAY T2
#4381
Originally Posted by outlandr91
Hey Guys,
I heard that production of Art's chassis squaring fixture will begin this Wednesday and Thursday and he wil be shipping them soon after that! Goodbye twaeked chassis
Is there a website or someplace I can check these out or see them?
#4382
Registered User
Did anyone else not go with the adjustable dampers and install the "fixed" dampers? I installed the adjustables, but didnt like them (couldnt get them to constantly change). Its like they would hop or miss a click. Without the oil, it was alittle easier to tell, but once I oiled up the shocks, couldnt work it out.
On another note, earlier we were going off on the car tweaking. After having ran the car for 12 heats I am too finding it to be kind of tweak prone, and not just from collision but from stuff I would consider minor pipe taps. I still think it is a non-issue, and I love the car, but I would still consider it a bit more tweak prone then most of the cars I've ran. I'll be getting a adding a solid topdeck to the car soon.
#4383
Suspended
You dont need to go with a solid top deck. Just counter sink the stock one and never worry about it again.
#4384
Now, do I use the same screws (not sure what the sizes are) or do I now have to install a longer set?
#4385
Originally Posted by Novarossi
After reading the tips of a few people, I went out and purchased some countersunk washers.
i used slightly longer screws than standard. more thread to grab, and less chance of tweak
#4386
#4387
Suspended
I didnt mean to use washers although it might work. I meant for you to actually counter sink into the carbon fiber.
#4388
#4389
The only thing I found with using washers is that they worked to good
I got hit real hard in one of my qualifiers and the washers held the tweak. It's a good temporary solution, but like mentioned above just properly countersink your deck or go all out and get a BMI chasis.
I also use longer screws where it won't interfere with either the bellcrank or installing the battery,this to will help.
#4390
What base gearing would people run on a T2 indoor on carpet with a 27T? Fairly tight track. Really struggled last night to get the gearing low enough and the motor was cooking at the end of the run.
#4394
Hi, I want solve the rear toe issue. Which part need to replace? Rear hub or rear upright? Or just use a shim? Thanks.
#4395
84spur / 19t pinion for 7.5 overall.
very tight indoor carpet track, with mainly hairpins on rubber tyres.
James
