Old 04-08-2006, 12:29 PM   #4321
Chris08527's Avatar
Trader Rating: 16 (100%+)
anyone have any rubber tire asphalt set-ups yet???
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 04-08-2006, 12:42 PM   #4322
Joep's Avatar
If you look here you'll find more than enough set-ups to start with
Xray T3 for dry and Xray T2'009 for rainy weather. Sponsored by: Myself and my wife.
Joep is offline   Reply With Quote
Old 04-08-2006, 12:53 PM   #4323
Nexus Racing's Avatar
The stock (progressive) springs haven't worked very well for me on asphalt. I've tried them for a couple of weeks off and on, and the car just always does funky things when on power with those springs installed.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 04-08-2006, 03:02 PM   #4324
rc-zombies's Avatar
SOLD! Pending payment.. thanks to all that inquired.
some decals left over from my T1..
7 sheets...these cost around $18-20 new..
all practically untouched.. only a few were cut out.
colors are:
1ea: Neon Yellow, neon pink, neon orange, purple, grey,
2ea: black&white
asking $10.00 shipped.
I can take paypal.
NEW XRAY T2-dsc01241.jpg   NEW XRAY T2-dsc01242.jpg   NEW XRAY T2-dsc01243.jpg   NEW XRAY T2-dsc01244.jpg
Old 04-08-2006, 10:41 PM   #4325
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
hi guys just want to ask what spring you used for tight ,medium aspalt track with couple of corners..some uses associated instead of xrays(silver and gold) but i tried to test which is harder between the associated silver and xray ithing xrays silver is alittle bit harder....cause i read a post that xray's springs that come with t2 is soft......actualy i suffer from oversteering.i was thinking mybe if i could change the springs to correct that problem....please help me .....thanx by the way t2 rock!!!!
pinggoy is offline   Reply With Quote
Old 04-09-2006, 12:37 AM   #4326
PitCrew's Avatar
On a small to medium indoor asphalt track I am running the following with great success. It has been working good with both a diff and a One way.
Front:
Spring: White (standard Xray)
Piston: One hole closed
Oil: Xray 30wt
Shock locations: Standard kit setting
Camber Link: Standard locations (inside lower) with 1mm shim on C-hub
-1.5 degrees camber
0 degrees kick up
0 degrees toe-in
Rear:
Spring: Yellow (standard Xray)
Piston: all holes open
Oil: Xray 30wt
Camber Link: Standard locations (inside lower) with 1.5 mm shim on top of hub
-2 degrees camber
0 degrees anti-squat
3 degrees total rear toe in.
PitCrew is offline   Reply With Quote
Old 04-09-2006, 08:22 AM   #4327
Get 'N' Faster!'s Avatar
has anybody else had any problem with there car tweaking easly. i was lineded up this weekend getting ready to start a heat when some guy nails me in the back and tweaked the car so bad i couldnt make right turns. im about to go check the bulkheads, hope there not bent
Get 'N' Faster! is offline   Reply With Quote
Old 04-09-2006, 09:01 AM   #4328
Send a message via AIM to R/C Anonymous
I have two of them and neither have tweak problems
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 04-09-2006, 10:57 AM   #4329
jaysimpson's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to jaysimpson
Originally Posted by Art Jensen
93.10 Paypal prepay including shipping in the lower 48.
Cool thanks Art, I believe I will getting one these.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
jaysimpson is offline   Reply With Quote
Old 04-09-2006, 12:24 PM   #4330
Thanks Promatchracer. I am hoping to have finished product to post pics of within a week to a week and a half. I already have a bunch of orders prepaid and am eager to get them filled. I think once the first batch goes out and people start using them alot of the tweak issues will go away. I noticed a bunch of buttonhead screws were made funny and were causing the top plate to shift when tightening them. I highly recommend anyone who owns a T2, whether you buy a squaring plate or not, to get countersink screws and countersink washers for the top plate. This will ensure a good square compression of the top plate to the bulkheads.
Art Jensen is offline   Reply With Quote
Old 04-09-2006, 08:31 PM   #4331
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
Anybody out there that says their this car does not tweak is full of crap. Plain and simple.
My cure for this problem was a team pickles top deck.
HRCRACER123 is offline   Reply With Quote
Old 04-09-2006, 09:23 PM   #4332
ottoman's Avatar
I guess I am full of Crap also... I have two T2's and neither one has had a tweak problem yet.
ottoman is offline   Reply With Quote
Old 04-09-2006, 10:19 PM   #4333
Registered User
Thumbs up
I have heard from other racers that have ran it, and just have been at races with them that say they do tend to tweak easily if impacted. I've not had an issue, but I've had very few, and only clean racing on mine. But unless something is physically bent, I would think any minor tweaking can be remedied by just loosening the top deck and retightening.
I've yet to see a car so tweaked though that it physically couldn't turn in one direction then another. Something like that is usual damage, and well, you did get rear ended hard. Things happen ..
Follow up though with what it was if you can.
Desolas is offline   Reply With Quote
Old 04-09-2006, 11:11 PM   #4334
pinggoy's Avatar
Today 11:24 AM
MY CAR WAS WAS CRASHED 3 TIMES ,TWICE BY OTHER RC CARS(1 WAS A NITRO AND 1 WAS A 1/12 SCALE) I WENT AIRBORNE,AND THE OTHER ONE I HIT A CORNER..BUT STILL I DID NOT TWEAK SO BAD..I DO ADMIT THE CAR TWEAKS ON A HARD IMPACT BUT NOT THAT NOTICABLE. MIGHT BE THE WAY WE BUILD OUR CARS OR WE SET UP OUR CARS. THATS WHY SOME T2 TWEAK SO BAD ...
Old 04-10-2006, 12:30 AM   #4335
Joep's Avatar
If you don't want any tweak, start racing with a Tank
Come on guys, tweak after a crash is normal. Ever seen Michal Schumacher crashing into another car / wall and not having to rebuild the whole car?
